Full-size Lego Car Can Hit 30km/h!
[Steve Sammartino] is a Melbourne entrepreneur, and he had an idea: could it be possible to design and make a functional full-size Lego car?
He sent out a single tweet to try to crowd fund the project:
Anyone interested in investing $500-$1000 in a project which is awesome & a world first tweet me. Need about 20 participants…
Not one, not two, but forty Australians pledged money to start this crazy idea dubbed the #SuperAwesomeMicroProject. With the money raised, [Steve] and [Raul Oaida] purchased over 500,000 Lego pieces and began the build in Romania, where [Raul] lives.
Now before you get too excited, the car is not “fully” made out of Lego. It features real tires and some select load bearing elements. That being said, the entire engine is made completely out of Lego. It features four orbital engines utilizing a total of 256 pistons. The top speed they tested it to was about 20-30km/h — it might go faster, but they didn’t want to risk a catastrophic failure.
Since its completion (it took nearly 18 months to build), it’s been shipped back to a secret location in Melbourne, but the team has made an excellent video showcasing the project. Stick around after the break to see your childhood dreams come to life.
[via Adafruit]
20 thoughts on “Full-size Lego Car Can Hit 30km/h!
    1. Superglue aka. cyanoacrylate glue was really only designed to glue your fingers together. Literally. It was designed for closing wounds, not gluing vases together.
      LEGO are made of ABS which is dissolved by acetone or MEK
      1. It wasn’t ACTUALLY designed for gluing fingers together! Tho since that turned out to be it’s primary use, whether you liked it or not, researchers at the Uni of Bradford, my home town, decided “why the hell not?” and researched it for clinical use, and it turned out to be ideal for smaller wounds and as an alternative to stitches. This research was in, if I remember reading about it right, the early 1990s. Superglue itself has been around much longer.
      1. They’re difficult to make work using the standard blocks. You have to open the cylinders up and file them down a bit so they don’t stick too much, and modify the valves for better flow to get speed out of the engine, but after you do that they run pretty smoothly and have more then enough torque to break standard lego axles.
        1. Note “difficult to source usable power”, I have seen them functioning with and without modification, without modification they will physically run but without much torque at all (although I have seen a car running on non modified pneumatic parts, it did not use a normal engine design though and was geared down heavily). I have seen the bored out parts running too, LPEPower actually sell lego engines with the modified pneumatic parts although they also need an external air compressor.
  1. those lego pneumatic engines actually produce insane amounts of torque, usually so much that lego gears get shredded. i built several but had to stop because they destroyed too many parts.
    1. My immediate thought was that it was an awesome project but that if I had the money and time I could easily do it too; and I am no “genius”. Still, I think lego car “races” would be an awesome idea. It could be scaled down to make the game more accessible; each car could need to carry a 20lb sack of potatoes or something.
Leave a Reply to PaulCancel reply
