Clever Mini-Matchstick Gun
Looking for a quick fun little project you can do for next to nothing? Why not make your own matchstick/toothpick launcher!
[Grant Thompson] the [King of Random] is at it again with another fun project that anyone can do — we just hope you’re responsible with it! All you need is some clothespins, a utility knife, and some form of munition — we like the flaming matches!
By cutting a few grooves into the clothespin, gluing it back together and re-configuring the spring layout, you can make a formidable mini-gun that can shoot upwards of 20 feet. Using a pointy toothpick it will skewer innocent fruits quite effectively too!
To see it in action and to learn how to make one yourself, stick around after the break.
Continue reading “Clever Mini-Matchstick Gun”
Hacking An Escape From East Germany
Some hacks are just for fun. Some make your job or your life easier. Once in a great while, a hack will save your family from an oppressive government. This is the kind of hack that [Günter] pulled off when he and [Peter] built a homemade hot air balloon to escape East Germany and the oppression of the Stasi in 1979.
Like many East Germans who weren’t in line with the Party, [Günter] found life unsatisfactory on his side of the Berlin Wall. Travel, job options, and freedom of expression were all severely limited. Aside from joining the Communist Party, the only option seemed to be escape to West Germany.
[Günter] and his wife [Petra] were inspired when [Petra]’s sister, who had escaped in 1958, came to visit. She brought with her a newspaper that covered the International Balloon Fiesta in Albuquerque, New Mexico. [Günter] and [Peter], whom he worked with, decided that they would conspire to build a hot air balloon capable of transporting them, their wives, and their four children across the border.
Theirs is an incredible story fraught with adversity. They ended up constructing three different balloons, all the while traveling further and further from home to avoid suspicion when buying large quantities of fabric. They had a lot of trouble finding the right propulsion method and ended up using pure oxygen. During the narrow window they had before [Günter] was due to report for military duty, the weather was unfavorable except for a short period after a front had passed through. They had no time for testing and just went for it.
Continue reading “Hacking An Escape From East Germany”
Hackaday Links: February 2, 2014
hackaday-links-chain
[Michel] was in need of a 9V battery connector, and in a brilliant bit of insight realized 9V batteries will plug directly into other 9V batteries (just… don’t do that. ever.) Taking a dead 9V, he tore it open, was disappointed by the lack of AAAA cells, and soldered some wires onto the connector.
Sometimes a project starts off as a reasonable endeavour, but quickly becomes something much more awesome. [Wallyman] started off building a hammock stand and ended up making a giant slingshot. We’re not one to argue with something that just became a million times more fun.
We’ve seen solder stencils made out of laser-cut metal, photoetched metal, plastic cut on a vinyl cutter, laser-cut plastic, and now finally one made on a 3D printer. It’s a pretty simple process – get the tCream layer into a .DXF file, then subtract it from a plastic plate in OpenSCAD.
Apple loves their proprietary screws, and when [Jim] tried to open his Macbook Air with the pentalobe screwdriver that came with an iPhone repair kit, he found it was too large. No problem, then: just grind it down. Now if only someone could tell us why a laptop uses smaller screws than a phone…
[Victor] has been playing around with an RTLSDR USB TV tuner dongle for a few months now. It’s a great tool, but the USB thumb drive form factor wasn’t sitting well with him. To fix that, he stuck everything into a classy painted Hammond 1590A enclosure. It looks much cooler, and now [Victor] can waterproof his toy and add a ferrite to clean things up.
Decoding News Helicopter Signals On YouTube
A serendipitous YouTube video recommendation led [Oona] to a raw copy of a news helicopter car chase video. While watching the video she noticed an odd sound playing from her left speaker. That was all it took to put [Oona] on the hunt. Decoding mystery signals is a bit of an obsession for her. We last saw [Oona] decoding radio signals for bus stop displays. She isolated the left audio channel and sent it through baudline software, which helped her determine it was a binary frequency shift keyed (BFSK) signal. A bit more work with SoX, and she had a 1200 baud bit stream.
Opening up the decoded file in a hex editor revealed the data. Packets were 47 bytes each. Most of the data packets was static. However, thee groups of bytes continuously changed. [Oona] decoded these numbers as latitude and longitude, and plotted the resulting data on Google Earth. Plotting her data against the position of the car in the video revealed a match. [Oona] had a complete track of the news helicopter as it followed the car. The telemetry data is in 7-bit Bell 202 ASCII, and is most likely part of an Interruptible Foldback (IFB) system used by the helicopter news crew and the studio producers. Click past the break for the YouTube video that started this all.
Continue reading “Decoding News Helicopter Signals On YouTube”
A Better USI I2C Library For The MSP430
USI
TI’s MSP430 chips are rather interesting – they’re low power, very capable, and available for under a dollar in most cases. Some of these chips, though, don’t have native SPI or I2C interfaces; instead, everything is done through a USI, or Universal Serial Interface module. [Jan] found the stock I2C USI module was a little rough around the edges, so he created his own.
[Jan] found the TI example code for using the USI as an I2C device overly complicated and something that an intern whipped up in a week and was never touched again. In response to this, he created a much, much simpler USI/I2C module that’s actually readable. It’s available over on the GitHub if you want to grab it for yourself.
Compared to the TI code, [Jan]’s library is dead simple. There are only two functions, one for initialization, and another for sending and receiving. Easy, small, and it works. Can’t do much better than that.
This Space Saver Puts The Squeeze On Your Keys
MultiKey
Keys? Who needs them? Well, pretty much everyone. You can’t deny that there are some ridiculously crowded key chains out there. It’s clear that [Robb] wanted to hit the other side of that spectrum when he started working on his latest multi-key project.
The term “multi-key” may be a little misleading as there are more than just keys on this tool. In addition to the bike lock, locker, work and house keys, there is a USB drive, bottle opener, screw driver and a couple of Allen wrenches. The side frames started out as part of an Allen key combo set; one not of the highest quality.  The Allen keys started snapping off during use which left [Robb] with a set of otherwise useless side frames. These became the platform of which [Robb’s] project is based. Adding a couple new bolts, nuts and a few modified keys got him the rest of the way there. A lot of thought went into which items to put into this tool and [Robb] explains his thought process in his step-by-step instructions.
The simple nature and potential for customizing makes this a great utilitarian DIY project. Although this may not be Janitor worthy, it will certainly consolidate some of the bulk in our pockets.
The Most Horrifying Use Of 3D Printing
As anyone with a Facebook account that’s over the age of 25 will tell you, 3D ultrasounds of fetuses are all the rage these days, with ultrasound pictures of the unborn recently taking the leap from black and white blobs to 3D – and 4D – images. With the advent of 3D printers, the inevitable has happened. Now you can order a 3D print of your yet-to-be-born progeny.
The company behind this – 3D Babies – takes 3D ultrasound data from weeks 24-32 and turns it into a 3D model. The printed 3D models sell for $800 for the full size version, $400 for a half-size version, and $200 for a quarter size version. It appears the 3D ultrasound data is simply wrapped around a pre-defined mesh, so while the resulting print may come out looking like your spawn, it’s still not a physical copy of the 3D/4D ultrasound data.
Despite the ‘creepy’ factor of these little bundles of plastic, we’re wondering why we haven’t seen anything like this before. Are there any obstetricians/radiologists/ultrasound techs out there that have experience with importing 3D ultrasound data into an editor of some sort? Notwithstanding any HIPAA violations, it seems it would be rather easy to turn this sort of 3D data into a printed object. 3D printing CT scans models can’t be the only other instance of this type of thing.
Thanks [Will] for the nightmares
