The BitBox Console Gets Upgraded
BitBox Rev2
The Bitbox, an open source game console, has received a number of updates in the past couple of months. Last time we covered this DIY console, [Makapuf] had just managed to get the first revision to run a simple game. The second revision will increase the colors to 32k, add another channel of sound for stereo, switch controllers from PS2 to USB, and add support for Olimex’s UEXT expansion devices.
While the hardware upgrades are impressive, there’s been a lot of work on the Bitbox software as well. A new game demo called Fire was created as a set of tutorials to help people start developing for the console. There’s also a BitBoy, a GameBoy emulator for the Bitbox. BitBoy is a ported version of gnuboy for the ARM Cortex-M4 processor that powers the Bitbox. It successfully emulates a number of commercial GameBoy ROMs.
We’re looking forward to seeing what’s next for the Bitbox. After the break, check out a video of BitBoy running on the Bitbox.
16 thoughts on “The BitBox Console Gets Upgraded
        1. So why don’t you want to use an ARM based microcontroller dev board, say an STM32F4 Discovery (the latest version comes with a touch panel LCD screen for less than £20), or if you insist on a VGA port then how about an FPGA dev board. One of those wth a programmer, VGA port, PS2 keyboard port, RAM, Flash ROM and everything you need to load up a soft CPU (there’s an ATMEGA core available, so you can then run the Marlin gcode interpreter on it) and a VGA controller can be had for less than £50.
  1. Well, nes would be the obvious next step ; C64 would be a fine target also, with its large catalog & small hardware ! Do you know of an acceptably accurate, opensource, portable, fast & *small* emulator – as in, I have 192k for ALL ram ?
    The bitbox emulator only needs SDL to work, so anyone can help from there :) !
      1. Accurate and fast tend to be mutually exclusive. The way most emulators get their speed is by deviating from the real thing’s behavior in ways that save time while having a negative impact on relatively few games.
        Also, I’m having trouble coming up with a standard of accuracy less vague than “acceptably accurate.”
          1. Try the really old releases of fceu (not fceux, not any of the other fceu-with-extra-letters). It’s not too inaccurate and reasonably fast and still just plain C.
            Unrelated: Two random “that’d be nifty” things I’d consider adding, if there’s spare I/O: VGA hotplug detect (pullup resistor on pin 11, if it’s pulled to ground there’s a VGA monitor attached) and reading DDC.
          2. (to rj) VGA hotplug : what would it be used for ? In conjunction with DDC ? As a standby switch ?
            I haven’t integrated DDC because I think there is not need reporting that a VGA screen supports 640×480 generally, but I might be mistaken. Maybe it can be used for widescreen detection, but that’s a bit of luxury ? It might not be practical discussing it here, can you hop on the mailing list discussing it (https://groups.google.com/forum/#!forum/bitbox-console)? If not, please answer there.
      1. well, while very interesting, stm429 wasn’t available as retail when the design was done, and is currently almost twice the price of 405 chip. I’d say that 256k of RAM is still not enough for a frame buffer at this resolution, so the DMA2D without external RAM might not be so useful, and I’d like to keep the design simple. Throwing more hardware is always possible but it will be difficult to justify being more expensive than a raspi…
Leave a Reply to SweeneyCancel reply
