2-Axis Solar Tracker Always Gets A Tan
Let’s face it — solar panels still aren’t that efficient. So why not pump as much juice out of them as possible? Building a 2-axis solar tracking unit can increase daily power output by around 30%!
[Jay Doscher] had his power go out back in 2011, and even though it was only for 12 hours, they realized how ill-prepared they were to deal with a power outage. Food was spoiled, flashlights were dead, candles were sparse… they needed to be prepared better for the next time this happened. This spawned one of [Jay’s] longest running projects on his blog Polyideas.
His goal was to build a fully automated solar tracking unit that could be setup anywhere, and automatically track the sun to ensure optimum ray catching. It makes use of a 12V gear reduced motor to provide panning, and a linear actuator with positional tracking to control the tilt. To track the sun he’s got a digital compass and an Adafruit Ultimate GPS breakout board. To control it all he’s using is an Arduino UNO, but he has been through multiple iterations including his first with a BeagleBone. It’s a very slick and well engineered system and [Jay’s] hoping to spread it around the world — the entire thing is open source. What a guy!
It’s not quite complete yet, but he’s got an amazing build log and a GitHub repository  filled with info — plus the following video showing it off in its current state!
http://www.youtube.com/watch?v=wIDUBpB8a5U
For a cheaper solar tracker you can build for fun, check out this baby-sized solar tracker that also uses an Arduino! Or how about this one built out of parts from the hardware store?
21 thoughts on “2-Axis Solar Tracker Always Gets A Tan
    1. We were doing this in 1976 with very simple analog parts (tracking the brightest part of the sky). Are you sure that is 30%? You should be getting a factor of 3 more power from tracking. It isn’t just the cosine of the angle. You get total reflection at low angles and some reflection all the time. So, tracking is a major improvement and great for a small installation. In solar farms there is shadowing of neighboring panels and it gets stupid pretty quickly.
  1. A couple of toughts:
    1. Sky tracking is OK only if you have direct sunlight. With diffused light (=cloudy days), solar tracking is not very effective.
    2. Is not zombie-apocalypse-proof. GPS would decay within a week without human intervention. 0/10. :D
    If you want juice, buying (building!) a solar panel with more cells would be the best option. Unless you live in Sahara desert.
  2. Thanks for all the comments! You can certainly use a larger panel, and the benefit is greater then as well. You don’t have to use a GPS unit- you can hard code the latitude and longitude into the sketch, but you’ll have to add a RTC since the Arduino doesn’t have one my default.
    1. Yes- even in winter here in California where the sun makes a sweep along the horizon fairly quickly, the Arduino sketch defaults to moving only every 10 minutes- so there’s not much power used- the Arduino idle uses very little.
  3. Nice, and a good exercise. But WAY overkill when a couple of sensors and a couple of opamps would do the job.
    Like I said, nice from a learning standpoint, and I’ll never say that’s a bad thing. But as far as building something like this for the job it does….. way overkill.
    1. As a general rule it is more effective to track knowing your lat/lon and time. Unless you are careful, on overcast days you might just burn more energy tracking the sun than you gain by proper aiming
    1. Why is GPS overkill? The object is to have a mobile system…without the GPS you would have to enter the lat/lon manually every time you you were in a (sufficiently different) location. The GPS and the compass would mean that you could plunk it down anywhere and not have to fuss with it.
    2. For the problems it solves with a portable solar tracker, the GPS unit is fairly cheap- the $40 unit is one of the most important parts of the project. As I posted earlier, you can hard code your latitude and longitude, but you’d still have to add a $20 RTC because the Arduino doesn’t come with a clock.
      If an enterprising individual wanted to create a single PCB with all the components onboard, you’d probably find this to be a relatively affordable solution compared to GoalZero stuff. You could even add dials or switches to manually enter your latitude and longitude and set the time, but you’d actually be adding significant cost because of that hardware.
    1. This project doesn’t require any other electronics to run- so no computation is needed by a smartphone or other device. If you use a 1-axis configuration, then you’d have to deal with the following drawbacks: A.) You would have to compute the fixed axis that your panel would roll on. B.) Your panel would usually be off-axis when operating during the winter or far from the equator, where the sun travels low across the sky.
      Additionally, the rotation motor and compass are fairly cheap components- so removing them would add complexity for the user and not much cost. If cost is a concern and complexity is not, a fully manual tracker may be ideal for you.
Leave a Reply to DC (@dragonnetworks)Cancel reply
