A Low Cost, Solar-Powered Swamp Cooler
A looming, torturous summer is preparing to bear down on many of us, making this dirt-cheap swamp cooler build an attractive hack to fend off the heat.
Though this is a pretty standard evaporative cooler, the design comes together in a tidy and transportable finished product. The base is a ~$3, 5-gallon bucket from a local hardware store with its accompanying Styrofoam liner. Three 2 1/8″ holes carved into the side of both the bucket and liner will snugly fit some inch-and-a-half PVC pipe with no need for glue.
One last cut into the lid to seat a small desk fan rounds off this build—or you can chop into the styrofoam liner’s lid if you prefer. The video demonstrates using a 15W solar panel to run the fan, and we have to admit that the cooler seems to be an excellent low-cost build. It does, however, require a frozen gallon jug inside to pump out the chilled air for around 5-6 hours per jug. Maybe one of our frugal and mathematically-inclined readers can throw out some guesstimations for the cost of stocking the bucket with a jug of frozen water a couple times a day? Video after the jump.
Continue reading “A Low Cost, Solar-Powered Swamp Cooler”
Recycled Foam Box is Now A Weather Station
Raspberry pi in foam box
When [Ioannis] received some high resolution LCD’s in a tattered foam box, he posed to himself a most interesting question – Should he throw the foam box away, or use it as a container for a project? Fortunately for us, he decided on the latter and threw together a very capable weather station!
Having only an hour to spare, [Ioannis] grabbed a Raspberry Pi, WiFi USB stick and a camera module and went to work. He mounted the camera module to the foam lid using a highly advanced technique, and soldered a cable that would power the device directly to D17 – a Zener diode that sits on the bottom of the board.
For the weather data, he’s using another design of his – the Sensor Stick. This nifty device — which we featured over the weekend — is about the size of a stick of chewing gum, and sports an array of sensors including the popular BMP085, which can measure pressure and temperature .
He wraps up everything using open source software to get the data from the weather station. Pretty impressive for an old foam box and an hours time! This would be an interesting start to a home automation system. Connect it to motorized windows and/or a sprinkler system and he’s on his way to claiming The Hackaday Prize.
Bacon Alarm Clock Won’t Burn Your House Down
Bacon Alarm Clock
If you have trouble waking up in the morning then maybe this alarm clock is for you. A bacon-aroma-releasing alarm clock!
Fueled by her love of bacon, Instructable’s user [llopez2005] decided she wanted to try making an alarm clock that would actually get her out of bed, hungry, and ready for bacon. Instead of trying to design a clock that would actually cook bacon — which might be a bit dangerous — she’s found an extract of bacon aroma which she could slowly release instead.
The clock makes use of an Arduino Uno with a RTC shield as well as a LED array for the clock’s display. The “bacon” is actually made out of bake-able clay, which sits on top of unscented wax, infused with the bacon aroma oil. The bacon and “bacon grease” sit in a baby frying pan over top of a small heater element designed for warming candles. Before the alarm goes off, a SSR turns on the element which slowly melts some of the wax, releasing its ever so delicious scent.
What we really like about the clock is the level of detail she put into its appearance. The base is designed after a small wood burning stove they have in the house, and she’s even made a Plexiglas display case for the frying pan — with holes to let the aroma out though of course!
Boost Peak Power Tracking Battery Charger
[Rusdy] is building a solar charger for his electric bike, and quickly realized the lithium cells in his bike wouldn’t work well with the most common charge controllers out there. Solar cells have an IV curve, of course, and this changes with the amount of sunlight, requiring some conversion circuitry. Most of the charge controllers out there operate in buck mode, but the commercial boost mode converters [Rusdy] needed for his 36V battery are pricey as all get out. What was [Rusdy] to do? Build his own Boost MPPT solar charger, of course.
The circuit used for the charge circuit is fairly similar to a boost converter, with a little bit of logic required to get the maximum power out of the solar cells. [Rusdy] had an Arduino lying around, so that took care of the logic, and by sampling the voltage and current with the analog pins, he can turn a MOSFET on and off to get the most out of his solar cells.
The finished product works perfectly with an efficiency greater than 87%. Charging current and the final trickle charge is adjustable through software, allowing [Rusdy] to get the most out of his solar panels and electric bike. The board itself is just a prototype and could use a layout revision, but we’ve got to hand it to him for cloning a >$300 charge controller with an Arduino and a few scraps in a part drawer.
2014 Imagine RIT: an Innovation and Creativity Festival in Rochester, NY
Metal Imagine RIT Sign
Every year, the Rochester Institute of Technology hosts Imagine RIT, an innovation and creativity festival “that showcases the innovative and creative spirit of RIT students, faculty and staff.” The festival is free to the public and really brings the community together to celebrate technology, science, art, innovation, and creativity! We had the chance to attend this weekend and we had a blast looking at all of the engineering projects on display.
Continue reading “2014 Imagine RIT: an Innovation and Creativity Festival in Rochester, NY”
Building A CO2 Laser In A Hardware Store
Over on the Projects site, [ThunderSqueak] is pushing the bounds of what anyone would call reasonable and is building a CO2 laser from parts that can be found in any home improvement store.
Despite being able to cut wood, paper, and a bunch of other everyday materials, a carbon dioxide laser is actually surprisingly simple. All you need to do is fill a tube with CO2, put some mirrors and lenses on each end, and run an electric current through the gas. In practice, though, there’s a lot of extra bits and bobs required for a working laser.
[ThunderSqueak] will need some sort of cooling for his laser, and for that he’s constructed a watercooling jacket out of 2″ PVC. In the end caps, a pair of brass pipe fittings are JB Welded in place, allowing a place for the mirror assembly and lenses.
The mirror mounts are the key component of this build, but the construction method is surprisingly simple. [ThunderSqueak] is using a few brass barbed hose fittings, with washers stuck on one end. The washers are drilled to accept a trio of bolts that will allow the mirrors to be perfectly parallel; anything less and the CO2 won’t lase.
The build isn’t complete yet, but having already built a few lasers, there’s little doubt [ThunderSqueak] will be able to pull this one off as well.
Bomb Clock Scares You Awake!
What better way to wake up than by fearing your impending explosion if you don’t hit the correct snooze combination! This is the DEVESTATOR (Translated), [Jacek’s] latest fun project, straight from Poland.
As an avid paintball and airsoft fan, [Jacek] wanted to build a unique clock — so he decided to make his own classic dynamite stick bomb… clock. He’s using a ATmega8 microcontroller at the heart of the project with both a DS1307 RTC and a DS1820 temperature sensor, because just for kicks, the clock also monitors ambient temperature!
To add to the realism of the project he also designed the PCB from scratch using Eagle CAD, which allowed him to make  the whole thing look even more threatening. To actually make the PCB he used the laminate thermal transfer method. The four buttons on the PCB allow you to scroll through the date, time, temperature, and set alarm times.
Oh and the “dynamite”? Paper towel rolls covered in red tape.
Continue reading “Bomb Clock Scares You Awake!”
