A Raspi Ambilight With HDMI Input
With the Raspberry Pi now most famously known as a $30 media PC, it only makes sense that the best uses for the GPIO pins on the Pi are used for an Ambilight. [Great Scott Labs] put up a great video on using the Pi as a uniquely configurable Ambilight with Hyperion and just about any video input imaginable.
This isn’t the first Ambilight clone [Great Scott] has put together, but for the first version the Ambilight functioned only under Raspbian and not any random HDMI input. The new version solves this by using an HDMI splitter box, feeding into an HDMI to composite converter, and finally into a USB composite capture dongle attached to the Raspi.
With the software in the instructions, the Raspi effectively mirrors the video coming from the video capture dongle. The Pi is running Hyperion to control a strip of WS2801 RGB LEDs, making the back of any TV glowey and blinkey.
Since [Great Scott] is using a component video signal as an input, the adapters necessary to have any device work with this Ambilight are readily available. We’d honestly like to see this build working with the old Commodore disk access screen border going nuts, so be sure to send that in if you ever get that working.
https://www.youtube.com/watch?v=tRDAzJrfZiM
19 thoughts on “A Raspi Ambilight With HDMI Input
  1. Only compatible with PC, a setup with 1 arduino and a 50 leds, is about 40€. Here, compatible with everything in HDMI, is about 100€.
    This sound fair to me.
    This guys is awesome, i didn’t even imagine a second that is was possible.
  2. If he’s using component video, it should be possible to do this without the Raspi…an STM nucleo with a M4 cortex should be fast enough to process the color signal at the edges of the picture…
Leave a Reply to JacekwwwCancel reply
