Plater Makes It Easy To Fill Your Bed Plate
plater
If you’re a 3D printing power user, you probably try to fit as many parts onto a single print job as possible. Most printing software has this built in to let you do that, but [Grégoire Passault] and his team thought they could do it better with their program Plater — it’s open source too.
They decided to make Plater after designing Spidey: an open-source 4-legged robot that makes use of 22 3D printed parts. The first few times they printed this took a long time because they had to manually arrange the parts — there had to be a better way!
Plater is a fairly simple program that lets you take in a bunch of STL files, set your print bed size and part spacing and then it creates an STL with as many parts in it as it can, organized on your print bed. Then you just have to load it up into your favorite slicing program and you’re good to go.
Seems like an excellent tool to add to your metaphorical 3D printing tool-belt!
35 thoughts on “Plater Makes It Easy To Fill Your Bed Plate
  1. More compressed would have put 2 of the flat rectangles inside each pair of long things.
    Even better would be that in addition to the flat rectangles between each u shaped piece.
    Seems like it would take up 2/3 the room to do it that way
    1. The term for this kind of thing (at least in the in the world of 2d files) is nesting. There’s a number of commercial packages out there, but I wasn’t able to find much for free. As Matthias_H points out, it’s not trivial to solve.
      I did try http://www.mynesting.com/ which has a pay-per-use model and will give you a preview of the layout it’s chosen. You then pay a few dollars for DXF output, which is a better model for the hobbyist than an up-front dollar charge, but obviously not as nice as free :)
      1. Most are coy about prices. Exactcam quote over $1500
        I’ve no experience beyond googling and a little playing, but have put some discovered prices on
        http://veg-buildlog.blogspot.com/2014/12/nesting-software-for-next-to-nothing.html
        There’s one for under $100 that works from early styles of .ai files from vector graphics software, there are some more recent plugins for Coraldraw and Adobe Illustrator from the same firm, and there’s a $100 offering for desktop plotters
        http://ain.e-Cut.ru is A1 Nesting, the cheapest offer
        http://Silhouetteamerica.com/ is the second cheapest
      1. My lasercutter software currently uses colors to differentiate between power/speed settings.
        And QCAD/CAM, which I’d like to use in the future, seems to use layers for that.
        So if possible, it would be best if both colors and layers could be preserved.
        As for the entities, I think if I explode everything in QCAD I’m left with lines, arcs and circles.
        But if it were at all possible, the best solution would be if everything could be preserved. (Maybe look at the entities to get the outline, and calculate a x-y move and/or rotation, which could then be applied to the whole original dxf? After which they could all be joined together?)
        I obviously don’t know much about how dxf files work though, so I could be hitting way off base here…
  2. “If you’re a 3D printing power user, you probably try to fit as many parts onto a single print job as possible.”
    Nope, you’d think so, but nope. If the print is a few hours long that’s enough. The risk of loosing all parts to the spaghetti monster if one fails is too great, and drawing fiddly boxes round all that with the excluder is not my idea of a good time.
    1. This. If a single piece breaks off the entire printbed will turn into spaghetti Bolognese. I always print one thing at a time unless they have a very good foundation and I’ve run the print before.
    2. Yep, and if you’re fully loading the board each time, the risk from running out of build platform if you start off center for some reason goes up significantly.
      I hope the program takes account of parts that grow outwards as they get taller (unlike me, with my last print – I’ll just call the stepped bottom a styling feature).
  3. similar problem is faced by auto UV mapping programs which try to place an ‘exploded’ 3d model made of triangulated sections in as small and as tightly packed volume as possible (allow rotation of parts to fit). Some literature on this. Its reuseable and problem is identical. I.e. cannot stretch faces to fit etc. UV has additional problem of needing to leave room around outside of each object and dealing with overlapping UVs and offsets. so 3d packing is subset of their problem.
  4. Hello,
    Actually, Plater is working on rasterised 2D projection of the shapes, so it may work with DXF in a very similar way, the only work tha twould be needed is importing DXFs and rasterizing it.
    Maybe we could do such a thing, because it seems there is indeed no free software that achieve good nesting…
  5. Hello,
    Actualy, the core of Plater is working on rasterised Bitmaps
    Hence, if we write the DXF import & export part, which is not very hard, and an algorithm to rasterise a DXF file, we could use it, this would be interresting I guess
  6. @JRDM, indeed, and an expert human operator will likely be better & quicker than any software actually
    However, we did the test and there is a lot of complicated examples where it is really hard to do it quicker
    Moreover, when dealing with parametric designs where the size of parts or quantity can be dynamically changed by user, having automatic process can be nice
    As stated above, this is NP-(very)-hard problem, so having a good heuristic is better than nothing
  7. I only run on delta’s so this program, although excellent, is fairly useless to me because it assumes a square buildspace. Delta’s are all circular. A problem most packers/slicers etc miss. Would be great if that was a selectable option.
  8. I only run on delta’s so this program, although excellent, is fairly useless to me because it assumes a square buildspace. Delta’s are all circular. A problem most packers/slicers etc miss. Would be great if that was a selectable option
    1. Hello,
      I’ve released a new version with support of circular plate
      Plates will not appear circular in the GUI, but the algorithm will generate patterns that can be put on circular plate
      Any feedback will be appreciated!
Leave a Reply to Builda3dprinter.euCancel reply
