This Useless Machine Now Plays With Fire
The Useless Machine, Candle Edition
Useless machines are a lot of fun, if not just a little overdone. Looking for a new twist, [bd594] decided to try making one that integrates a candle — it works quite well!
While not quite as impressive as some of [bd594’s] previous projects, like his rendition of Bohemian Rhapsody on old school computer equipment, we like how he used regular DC motors in this design, instead of servos (the easy way).
A PICAXE14M2 microcontroller controls the H-Bridge responsible for the geared DC motors (taken from a Mac floppy drive), and a light sensor checks for the flame. He’s also made use of some NPN transistors to invert some logic levels to show you if you’re running low on I/O pins, its always possible to incorporate some other discrete components like a transistor to achieve your design.
Among others, some great alternative spins on the “useless machine” include the moody useless machine, an even more useless machine (featuring 8 switches!), a pull-string version, and even a rather ridiculous elevator button pressing useless machine!
Stick around to see this one put out the candle (Caution: Very exciting).
24 thoughts on “This Useless Machine Now Plays With Fire
  1. Nice! Though, a suggestion for an upgrade: cut out a portion of the bottom of the candle holder and put a more sensitive light sensor facing up, though the semi-transparent wax, so one can’t tell how the candle light is being sensed.
    1. Aha! Very “meta”. You have made the leap from “useless machine” to “useless comment”. Either that or you have not actually watched the video. The candle is snuffed out. The wick is not pushed into the wax.
  2. I’m just thinking how this does not need a microcontroller at all.
    An ambient light comparator can be made with two LDRs in a Wheatstone bridge that turns out a voltage differential when one gets more light than the other. A small capacitor provides for delay. This voltage differential can be used to run a simple four transistor H-bridge where both legs have a microswitch that cuts the current at the extremes of movement.
    When one LDR gets more light, a voltage differential appears in the bridge, which triggers a comparator, which changes the logic level controlling the H-bridge direction at a delay provided by the capacitor, which moves the motor forward until it hits the limit switch, stays there until the capacitor delay, then winds back and hits the other limit switch and stops until there’s enough difference in light at the LDR for long enough to trigger the circuit again.
      1. What is the real justification for NOT using a micro? You keep hearing this kind of comment, but I don’t get it. Yeah, there was a time not very long ago where a microcontroller system was more expensive and more complex. But now, this just doesn’t even make sense. Just do it the ‘hard way’ for the hell of it? Does it make one feel smarter? Do you think people that use micros DON’T know how to do it the hard way just because they used a micro?
        It is cheaper and more simple, and perhaps even far more reliable to use a micro to replace a ton of components with just 1.
        I am not busting your chops. I am genuinely curious. Why?
        1. ” Do you think people that use micros DON’T know how to do it the hard way just because they used a micro?”
          Yes. Mostly.
          Probably about 80% of the people who do these kinds of hobby projects don’t really have a working knowledge of analog/discrete electronics because they’ve never had to try and engineer something out of discrete parts. Even more people just throw an arduino at it, and hold it “advanced stuff” to use just the IC on its own because they couldn’t wire the board for their life.
          And if the thing ever breaks, it’s easier to find a replacement BCxxx transistor than a microcontroller and a programmer and compatible software and reverse engineer the original. You know flash memory has finite data retention time and may corrupt over time, right?
          1. Really? No. I didn’t know that! Only you do, because you’re special. ;)
            Us engineers use the KISS principle, well, because apparently we’re stupid.
  3. +1 to [justice099] and [tekkieneet]
    Props to [bd594], though. This is awesome. These useless machines always seem to have a personality, and this one somehow kicks it up a notch. Loved it.
  4. Why is anyone upset about how or why this project was made? It’s a hobby, a passion, something we humans use to entertain, learn, and grow. I too would do this project differently. However this is creative. Someone took the time to build it because they wanted too, stop passing judgment. Nobody made your read or watch this video, it was voluntary.
Leave a Reply to BB GunCancel reply
