Ask Hackaday: Who is Going to Build This Pneumatic Transmission Thing?
fluid_transmission
Disney research is doing what they do best, building really cool stuff for Disney and telling the rest of the world how cool they are. This time, it’s a very low friction fluid transmission device designed for animatronics.
From testing a few toy robotic arms, we can say without a doubt that servos and motors are not the way to go if you’re designing robots and animatronics that need lifelike motion. To fix this, a few researchers at Disney Pittsburgh have turned to pneumatics and hydraulics, where one joint is controlled by two sets of pistons. It’s extremely similar to the pneumatic LEGO, but more precise and much more lifelike.
The system uses a pair of cylinders on each joint of a robot. Disney is using a rolling diaphragm to seal the working fluid in its tubes and cylinders. This is an extremely low-friction device without any shakiness or jitters found with simple o-ring pneumatics and hydraulics.
The system is backdriveable, meaning one robotic arm can control another, and the other way around. Since we’re dealing with hydraulics, the cylinders (and robotic/animatronic devices) don’t need to be the same size; a small device could easily control a larger copy of itself, and vice versa.
The devices are fairly simple, with gears, toothed belts, and bits of plastic between them. The only unique part of these robots is the rolling diaphragm, and we have no idea where to source this. It looks like it would be great for some robotics or an Iron Man-esque mech suit, but being able to source the components will be a challenge.
You can check out the videos of these devices below, and if you have any idea on how to build your own, leave a note in the comments.
Comments
  1. GuruBuckaroo says:
    I realize this is a little bit of a .. well, a hack, but seems like a condom would make a good rolling diaphragm at least for proof of concept. Wear would be an issue, of course, but as long as the gap it’s filling isn’t too wide, it should hold a decent amount of pressure.
  2. Water balloon with the end trimmed off would probably do in a pinch for prototyping, yeah?
  3. the gambler says:
    this may sound crazy but even though the results are a bit different the design is very similar to a patent that dana has on a transmission from back in the early ’90’s. I can’t find it right now because they have so many but it is similar.
  4. Sci says:
    The use of the rolling diaphragm is very clever! I like this!
    Shame it’s proprietary, but hobbiests should be able to reproduce it non-commecially with basic home-casting materials.
    • dana says:
      Is it patented? I didn’t do a search, but if it’s not patented then it’s fair game.
      I suspect based on no evidence that even though the application is unique, the principle of a rolling diaphragm pneumatic cylinder has prior art.
  5. nick says:
    Years ago we used Belofram pneumatic cylinders on slitting machines http://www.belloframdiaphragms.com/
  6. ehrichweiss says:
    You’d have to watch what the liquid was but you could probably use dental dams, or a silicone sheet like this http://amzn.to/ZU1XCM
  7. TheNeatWhale says:
    A way to create this could be similar to a hydraulic braking system in a car, mountain bike or motorbike, the idea being a hydraulic piston driving another hydraulic piston, one lever/pedal activated and the caliper piston being driven by the displaced fluid. If you attached two brake calipers end-to-end then it could theoretically do the same thing by pushing one piston to actuate the other.
    • TheNeatWhale says:
      Also the return of the actuating piston will create a negative pressure differential which will then return the driven piston.
      I understand that a car or motorbike will make use of a master cylinder to do the driving but in its simplest iteration, the two calipers or any hydraulic actuator with a length of hydraulic line linking them will do the job.
  8. earl says:
    It’s always nice seeing “older” or “analog” solutions pretty much kick ass over our current electric/digital efforts.
    • Dan says:
      The downside is the limitation of distance from the actor. The advantage that electrical impulses have is that they can be encoded, then transmitted over long distances with no loss of fidelity.
      This is probably a superior solution for the specific application that Disney is designing it for. Perhaps it would have a place in robotic surgery, or some other dangerous environment where high resolution, control and feedback are required, but I don’t think it’s going to kill electric robots.
      • MrX says:
        In some applications this can lead to great improvements. If your robotic application allows it, with this system you can offload the control gear off the moving gear. In other words, the servos/motors needed to control a robot arm do not need to be in the arm itself!
  9. earl says:
    Why pressurize the air? I’m assuming to tighten up the hoses, less flex=more response?
    • markaeric says:
      Probably because if the pressure is too low, it’ll be easily compressed between the two ends, leading to poor performance.
    • Maxzillian says:
      Once any load (even friction) is on the system, air will pressurize in the lines, making the action delayed and limited in travel by taking up some of the displacement offered by the driver. By pressurizing the lines the air is already compressed above and beyond what the load can generate so it behaves as though the lines were filled with a fluid. Hose flex is a factor, but when using air, the air compressing has a much bigger effect.
      The genius is they can somewhat dampen the action by controlling the air pressure.
      • M says:
        Not only can they dampen the action by controlling the pressure, it wouldn’t be hard to make the dampening variable by adding a third cylinder to each line, with the position set via stepper motor to change the overall pressure in the line. You could vary system pressure in response to position of the input or output shaft, or based on the speed or acceleration of the input shaft.
    • targetdrone says:
      @Earl,
      They pressurize the air because air is a compressible gas. If they didn’t pressurize it, moving the source would simply squish the air in the cylinders and hoses without transferring much of the force to the load. By pressurizing the system, the gas has less ability to be compressed, and thus it has less “slop” in controlling the load. It doesn’t “tighten the hoses” as much as it “tightens the air inside the hoses.”
      Fluids, like water, hydraulic fluid, or brake fluid, are almost perfectly incompressible, so they transfer the force almost perfectly with no extra pressure. But because the water (or other fluid) is much heavier than air, moving them has to account for the inertia of the fluid, and has increased friction losses in the hoses, much more than a pressurized air system. To get a fluid based system moving, your power source (which starts from zero) has to keep adding power until it overcomes all the friction and inertia. That shows up as sudden starts and stops at the start and end of travel, which is bad for a robot you’re trying to make look lifelike. Fluids are also much more rigid than compressed air, and would show every slight vibration in the source power, including any steps in the stepper motor driving it. The compressed air is still a gas, and is still very compressible, and it is much springier than fluid. It might be more forgiving (and perhaps more lifelike) in an animatronic model.
      • Alan says:
        Adding a gas dampener to a fluid system will greatly reduce the sudden start-stop (for example: gas-charged shocks, or water-hammer in a big building, etc…).
        Also, adding spring-charged or flexible, shock absorbing connecting rods/arms/mounts better simulate the “stretch under force” encountered with living muscle-tendon-ligament systems.
    • Add to all the above: It also takes out slack in the linkage/toothed belts.
  10. Koplin says:
    My first thought before seeing the comments was a condom as well. Might try finger cots, aka single digit gloves
    The great oracle Google shows us that rolling diaphragm are not uncommon or proprietary.
    http://www.ierindustries.com/pdfs/Rolling%20Diaphragms.pdf
    http://www.controlair.com/index.php/diaphragm-air-cylinders/rolling-diaphragm-cylinders
    looks to me like you could put a finger cot on a a few properly sized pieces of PVC and get something working. I doubt they would last for more then a bit of testing but for the cost it would be cheap entry into the field.
  11. James Nugen says:
    At the bottom of the Disney Research page is a link to the conference paper:
    http://www.disneyresearch.com/wp-content/uploads/Project_FluidSoftActuator_IROS14_paper.pdf
    It contains the part numbers of the “off the shelf” diaphragm and diaphragm cylinder they used. The cylinder is a “Control Air 349-180-009″:
    http://www.controlair.com/index.php/diaphragm-air-cylinders/small-bore-cylinders
    I could make a comment about lazy article writers, but I won’t! :)
  12. kramboz says:
    Now they need hydraulic amplifiers and suddenly… analog mechsuits!
  13. rexxar says:
    This is awesome! I can’t wait to see what someone does with this!
  14. Haku says:
    Disney giving away their ideas? Doesn’t feel right, I mean they’re usually the one trying to stop innovation…
    https://torrentfreak.com/letting-critical-infrastructure-get-regulated-cartoon-industry-141005/
  15. simonkuehling says:
    I have succesfully used PVC pond liner a while ago to repair a boost pressure actuator on an old diesel engine. These also have a rolling diaphragm inside for minimal friction.
    The repair easily stood up to 30k kilometers on that car engine – so it may be a good choice for other applications as well.
    It’s just a matter of thermoforming the foil into a cup shape with a hot air gun…
    http://simonkuehling.de/bulli/lda3/
  16. echodelta says:
    Rolling diaphragm…raspberry! What crap, reinventing the wheel. Fancy ‘o’ ring that won’t leak till it fails. It’s thick and it flexes in tight turns. Foreskin or turtle neck skin really.
    If servos are jerky it is bad programing and slop. Just look at Holeywood animation if you can see fluid motion. The people who have grown up on it don’t know motion…hint, it takes a few hundred frames per second and much more work. In watching the video I saw delay and un-damped oscillations that would flunk if used as a pitch bender on a synth.
  17. StarDreamer says:
    For a hobby use : a short section of bike tire inner tube ?
  18. Rasputin says:
    “Disney Research Pittsburgh” is Disney setting up Carnegie-Mellon students/labs with design projects, which this is. As previous comments have pointed out there isn’t much that’s revolutionary about this, but it is the usual press release “Revolutionary _______ will fix/lead to/cure _______ Real Soon Now”. Given our borked patent system, they’ll likely file on it but that doesn’t really mean anything.
    List of other stuff they’re working on: http://www.disneyresearch.com/research-labs/disney-research-pittsburgh/
  19. BotherSaidGCHQ says:
    Fill it with ferrofluid. No diaphragm needed *AND* you can make the whole thing move without moving parts.
    (scuttles off to the Patent Office PDQ)
  20. cplamb says:
    Low temperature differential sterling engines makers have found that a graphite piston in a glass cylinder makes for very low friction. I don’t know about how high a pressure it can hold however.
    • denis says:
      probably fairly high, vacuum pump in mercedes for soft closure amd central locking is graphite internally. the air suspension is also rolling diaphram as per any car or truck with oe air susoensuin. mercedes, audi, landrover, and almost all?? “eurotrucks” im sure american trucks are still on leaf springs :p
  21. Alan says:
    But why did they “re-invent the wheel” ?
    Pnumatic cylinders and diaphrams have been used as actuators for 150+ years.
    The “rolling-seal” isn’t new either, but the patents are from a long time ago so Disney doesn’t have to worry about that.
    I have a 100 year old camera remote-control that is almost exactly like the passive piston-to-piston actuator they’re demonstating… the major differences are that the camera remote is made out of ancient plastic and it multiplies force by having a larger volume stroke on the control cyler side.
    Oh well, I guess there isn’t anything new under-the-sun… everything is a re-embodiment or refinement of ideas that came before.
  22. Json says:
    Air shocks for cars and trucks use rolling diaphragm
  23. deadlydad says:
    Here is a PDF all about rolling diaphragms from the company that invented them.
  24. electrical motors/servos are not the problem. The problem is poor control of electrical motors/servos. That said, this looks like a very interesting setup.
  25. Jonathan Phelps says:
    springbrake chambers on semi-trucks use a possibly suitable diaphragm for this application.
  26. Greg says:
    Use condoms as diaphragm material :-). Durable, thin, lubricated, cheap, readily available. :-)
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,232 other followers
