Color Light Painting With A 3D Printer
Light painting, or taking a few RGB LEDs, a camera with a long exposure, and turning the world into Tron, has been around for a while. We haven’t seen many people using their household CNC machines for the same effect. [ekaggrat] is the exception. He’s already used a 3D printer to do some light painting, and now he’s doing it in color.
This build is an extension of an earlier project we saw that used a white LED to draw pictures within the build volume of a delta printer. Just like the last time, [ekaggrat] wired LEDs up to a RAMPS board and toggled pins with the M42 command. This build merely triples the complexity of the wiring; the RGB LED is wired to pins 4,5, and 6 of the controller board, and the shutter release button of his camera is wired up to pin 11 with an optoisolator.
The ability to blink out Gcode is one thing, getting his two-year-old daughter to stand still for 3D scanning is another thing entirely. With the data in hand, [ekaggrat] was able to run this model through a script that would generate a light painting of his daughter. You can grab the script for that on GitHub, or check out the video below.
21 thoughts on “Color Light Painting With A 3D Printer
  1. That is really neat!
    Useless, but neat!
    Note: I can see the utility in the learning that went into achieving this – particularly the 2d interpolation in the title sequence
        1. Might be on very large area prints, but some automation of the camera (USB->chip-of-choice->camera-trigger) and maybe breaking the print down vertically into smaller layers so you could “see” into them better.
  2. It seams like you could get the same effect with an LCD monitor and a translation stage that moves the LCD in front of the camera in controlled steps. The camera angle would need to be set for the appropriate view. One slice of the 3D volume would be displayed on the monitor, a photo taken, the LCD moved, then the next slice displayed, and so on.
    1. Because it’s two layers of video. One is the un-touched original video that just shows the blinking, moving print head, and the other is a brightness or luma mask that is updated every time a point gets above a certain brightness (the LED glows). That let’s the trail of light appear to stay behind after the print head has moved the LED.
    2. u mean the video? for the pics the camera was in bulb mode and the head has no lighting so cant be seen, For the video the video was post processed in kdenlive to get the led points from every frame to overlap in the next frame to create the line effect … so even i have no idea why ther is no blur :) the video or pics are not fake FYI
      1. Since it’s 3D perhaps the camera should slightly rotate around the target while the image is being constructed, for a more impressive effect.
        Although you’d have to try to see how it comes out.
Leave a Reply to DaveCancel reply
