Hackaday Prize Entry: 3D Printed Modular Keyboard
There is a big community of people creating all kinds of synthesizers, but until now no one has attempted to make a keyboard controller like the one [Tim] created. Not only has he created the keyboard synthesizer, but he’s developed one that is modular and 3D printed so you can just expand on the synth you have rather than go out and buy or build a new one.
The design has a lot useful features. Since the design is modular, you can 3D print extra octaves of keys if you need, and simply build off of the existing keyboard. The interior has mounts that allow circuit boards to be screwed down, and the exterior has plenty of available places to put knobs or sliders. Anything that could possibly be built into a synthesizer is possible with this system, and if you decide you want to start small, that’s possible too!
All of the design files are available from Pinshape if you want to get started. The great thing about this controller is that you could use a 555-based synth in this keyboard controller, or a SID synth, or any other synth you could think of!
The 2015 Hackaday Prize is sponsored by:
Adding Tie Down Points To Almost Any Car
You know, sometimes it’s the simple hacks that get our attention.  If you have a roof rack, and use it often to shuttle things around, adding these stow-away, front tie downs might be for you.
Most all cars will have a few bolts along the top of the fender that ties into a semi-rigid or structural part of the vehicle. [Andrew Morrow] used about 12 inches of nylon strap, added a hole to the both ends, and attached them to the fender bolts. With the hood closed, he now has a convenient tie down location for what ever he’s hauling around.  We love that when not in use they simply can be stored beneath the hood. Hidden away, but not something you’ll forget to bring with you, or easily lost.  Just make sure that they don’t come in contact with moving engine parts, or hot exhaust manifolds.
Hackaday Links Column Banner
Hackaday Links: July 12, 2015
Adafruit is working on a series of videos that’s basically Sesame Street for electronics. G is for Ground is out, where [Adabot] discovers pipes and lightning rods are connected to ground. Oh, the rhyming. Here’s the rest of the videos so far. We can’t wait for ‘Q is for Reactive Power’.
Think you’re good enough to build an airlock 70 cubic meters in volume that can cycle once every thirty seconds? How about building a 500 mile long steel tube with zero expansion joints across active fault lines? Can you stop a 3 ton vehicle traveling at 700 miles per hour in fifteen seconds? These are the near-impossible engineering challenges demanded of the hyperloop. The fact that no company will pay for this R&D should tell you something, but that doesn’t mean you still can’t contribute.
Calling everyone that isn’t from away. [Paul] lives near Augusta, Maine and can’t find a hackerspace. Augusta is the capital of the state, so there should be a hackerspace nearby. If you’re in the area, go leave a message on his profile.
Last week we found memristors you can buy. A few years ago, [Nyle] found them while hiking. They were crudded up shell casings, and experiments with sulfur and copper produced a memristor-like trace on a curve tracer.
Need a way to organize resistors? Use plastic bags that are the same size as trading cards.
The Arduino is too easy. It must be packaged into a format that is impossible to breadboard. It should be shaped like a banana. Open source? Don’t need that. The pins are incorrectly labelled, and will be different between manufacturing runs.
diy foot switch
Foot Pedal Switch Specifically Made For PCB Drilling
Using the Toner-Transfer and Etch method for making prototype circuit boards is fairly common. One downside to this process is that any holes still need to be drilled. [Giorgos] hand drills boards all the time. He has a Dremel with a drill press attachment but he still prefers using a small pen-style mini drill to make the holes. There is one problem with this tool though, the on/off switch is in an non-ergonomic location. After flipping the switch tens of times during a drill job, [Giorgos] has felt some digit discomfort. He knew there had to be a better way.
His solution: a foot pedal on/off switch. This isn’t some off-the-shelf foot switch, [Giorgos] made it from parts and pieces kicking around in one of his junk drawers. The foot pedal frame is made from acrylic sheet. A couple of hinges allow the pedal to press down on an old switch, very similar to the ones found in guitar effect pedals. This switch was heavy-duty and had a strong spring that easily pops the switch and pedal back up after being pressed.
Wiring was easy, the positive lead of the DC wall wart was split and attached to the pedal’s switch. Pressing the switch makes or breaks the power connection, turning the hand-held drill on and off. [Griorgos] solve his ergonomic problem and cleaned out his junk drawer without spending a dime. We’d say that’s a triple win!
CCCamp 2015 Rad1o Badge
Conference badges are getting more complex each year. DEFCON, LayerONE, Shmoocon, The Next Hope, Open Hardware Summit, The EMF, SAINTCON, SXSW Create, The Last Hope, TROOPERS11, ZaCon V and of course the CCC, have all featured amazing badges over the years. This years CCCamp 2015 rad1o badge is taking things several notches higher. The event will run from 13th through 17th August, 2015.
The rad1o Badge contains a full-featured SDR (software defined radio) transceiver, operating in a frequency range of about 50 MHz – 4000 MHz, and is software compatible to the HackRF One open source SDR platform. The badge uses a Wimax transceiver which sends I/Q (in-phase/quardrature-phase) samples in the range of 2.3 to 2.7 GHz to an ARM Cortex M4 CPU. The CPU can process the data standalone for various applications such as FM radio, spectrogram display, RF controlled power outlets, etc., or pass the samples to a computer using USB 2.0 where further signal processing can take part, e.g. using GnuRadio. The frequency range can be extended by inserting a mixer in the RF path. Its got an on-board antenna tuned for 2.5GHz, or an SMA connector can be soldered to attach an external antenna. There’s a Nokia 6100 130×130 pixel LCD and a joystick, which also featured in the earlier CCCamp 2011 badge known as the r0ket.
A 3.5mm TRRS audio connector allows hooking up a headphone and speaker easily. The LiPo battery can be charged via one of the USB ports, while the other USB port can be used for software updates and data I/O to SDR Software like GnuRadio. Check out the project details from their Github repository and more from the detailed wiki which has information on software and hardware. There’s also a Twitter account if you’d like to follow the projects progress.
This years Open Hardware Summit also promises an awesome hackable badge. We’ll probably feature it before the OHS2015 conference in September.
Thanks to [Andz] for tipping us off about this awesome Badge.
3D Printering: The Makerbot Class Action Suit
Since the 5th generation of Makerbot 3D printers were released at CES in 2014, there has been an avalanche of complaints about the smart extruder in these printers. Clogs were common, and the recommended fix was to simply replace the extruder. The smart extruder is a $175 part, and the mean time before failure is somewhere between 200 and 500 hours. With these smart extruders, you’re looking at a new extruder every dozen prints or so. Combine this with Makerbot’s abdication of open source values, and it’s easy to see why no one in the know would buy a Makerbot.
The performance of the 5th gen Makerbots is also reflected in the Stratasys stock price. The stock has tanked, from a high of $130.83 in early 2014 to a low of $31.88 a few days ago. This has investors calling for blood, and now there’s a class action suit claiming Stratasys violated securities laws. The court docs found by the folks at Adafruit allege Stratasys rushed the 5th gen Makerbots into production resulting in an avalanche of negative feedback, warranty claims, returns, and misled investors until the stock collapsed when the market was made aware of these issues.
The court documents allege Stratasys and Makerbot touted the incredible ease of use and ‘unmatched’ quality of the 5th generation of Makerbots, while former Makerbot employees confirmed known issues with the smart extruder. The 5th gen Makerbots were rushed into production without proper testing for performance and reliability and no standardized testing and validation program. In short, Makerbot itself didn’t know how bad the smart extruder was, but shipped the product anyway. This in turn hurt sales, with one sales executive leaving the company as he “did not want to sell the 5th generation printers after learning about the defect issues because he has a ‘conscience’.”
Despite this, those in charge at Makerbot and Stratasys continued to make misleading  positive claims about the reliability of their printers and how the printers were received by the market. This is the crux of the lawsuit, and something that points to an artificially inflated stock value.
The plaintiffs for this lawsuit are limited to Stratasys stock holders, and anyone out there who only owns a 5th gen Makerbot will sadly be ignored in this lawsuit. Still, if the claims of this lawsuit are true, Stratasys and Makerbot are in for a world of hurt; this is an alleged violation of federal securities laws. demanding a jury trial. Popcorn abounds, and as always, [Zach] and [Adam] came out ahead.
Hackaday Retro Edition: Androids And Amigas
Tiny ARM boards are everywhere, and if the Raspberry Pi is any indication, they’re mostly used for emulating old consoles and computers. With only a $30 single board computer, it’s easy to emulate an SNES, Apple II, C64, or any of the other piece of classic 80s or 90s hardware.
Understandably, there will eventually be a few projects and products that hope to capitalize on this retro trend. Few of them will go through the rigamarole of actually licensing the relevant IP. The Armiga is one of these projects. It’s an emulated Amiga 500 with 1MB of RAM packaged in what looks like a 3.5″ external floppy drive.
Inside this tiny little box is a dual core ARM for Amiga emulation. For the most part, this is just a basic Android system, but the real selling point of this system is the Armiga Project software. This is a full emulator and game browser that also includes a legal (!) copy of Kickstart 1.3. The ‘upscale’ version of the Armiga also includes a floppy disk controller and drive, should you ever want to dump all those old floppies sitting around in your attic.
This isn’t the first time we’ve heard about the Armiga. It was a crowdfunding campaign a year ago that was unsuccessful for reasons we can’t comprehend. The creators of the Armiga have forged on, and now these tiny little boxes of guru meditation have started shipping. The Beta units have sold out and there’s a waiting list for more.
