Just Don’t Call It An Old Remote
[Hari Wiguna’s] father is ninety years young. He started having trouble pushing the buttons on his TV remote, so [Hari] decided to build a custom remote that just has the buttons his dad needs. Oh, and the buttons are big.
There are a few interesting things about this project. [Hari] wanted to maximize battery life, so he went through a good bit of effort to keep the processor asleep and minimize power consumption. The remote is programmable, but [Hari] didn’t have access to his dad’s remotes. His answer was elegant. He used his Android phone to mimic the required remotes and provided a way for the remote to learn from another remote (in this case, the phone).
Continue reading “Just Don’t Call It An Old Remote”
Harvard’s Microrobotic Lab Sinks RoboBees And Claims It Was On Purpose
What do you call tiny flying robots that undoubtedly emit a buzzing noise as they pass by? Mosquitoes are universally hated, as are wasps, so the logical name is RoboBees.
The Wyss Institute for Biologically Inspired Engineering at Harvard University has been cooking up these extremely impressive tiny robots in their Microrobotics lab. The swarms use piezoelectric actuators to produce the mechanical force to drive the wings, which can be independently controlled.This isn’t the first time we’ve looked in on the Robobees, but the most recent news revealed the ability to swim, and dive (term used generously) into water.
This may not sound like much, but previously the robots lacked the ability to break the surface tension of water. To sink, the wings need a coating of surfactant. Once submerged, the bots lack the ability to transition back from water to air. But we won’t be surprised to see that ability added as a feature while the scope of the project continues to creep. So yes, you can jump into water to escape bees but not to escape Robobees.
Diving isn’t the only wonder to behold. The ‘head’ of the RoboBee is utterly fascinating. It’s constructed by folding the PCB into a pyramid like structure, 4 sides of the head include a photo-transistor covered by a diffused lens which the bot uses for self positioning by sensing changes between the bright light of the sky and absence thereof below the horizon. This concept is taken directly from biological self-righting systems found on the head of most insects, however Harvard’s version has one more sensor than the stock 3 seen on insects. Take that, nature!
Continue reading “Harvard’s Microrobotic Lab Sinks RoboBees And Claims It Was On Purpose”
Maximizing A Solar Panel
Solar panels seem like simple devices: light in and electricity out, right? If you don’t care about efficiency, it might be that simple, but generally you do care about efficiency. If you are, say, charging a battery, you’d like to get every watt out of the panel. The problem is that the battery may not draw all the available current, basically leaving capacity on the table.
The solution is a technique called MPPT (Maximum Power Point Tracking). Despite sounding like a Microsoft presentation add on, MPPT uses a DC to DC converter to present a maximum load to the solar cell while providing the desired current and voltage to the load. MPPT is what [Abid Jamal] implemented to manage his solar charger.
Continue reading “Maximizing A Solar Panel”
Hackaday SuperConference Call For Proposal
We’ve been keeping pretty quiet about the Hackaday SuperConference, but rest assured a full-blown announcement is on the way soon. For now we need your help getting the word out to presenters. Do you have a favorite hardware designer, hacker, or project? Get to work convincing them to Submit a Talk or Workshop proposal for the Hackaday SuperConference. Of course if you yourself fall into one of these categories, consider this your invitation to submit! Proposals are due October 10th.
The Hackaday SuperConference is the hardware con you’ve been waiting for. The two-day event will be held in San Francisco on November 14th and 15th. It features workshops and talks on hardware creation with topics like hardware engineering, creativity in technical design, product design, and prototyping. The winner of the 2015 Hackaday Prize, Best Product, and runners-up will be announced at the SuperCon.
The 2015 Hackaday Prize is sponsored by:
Apple Cider Press Is Just In Time For Fall
Do you like hacking? Do you like apple cider? Do you like ceiling fans? If you answered “yes” to any of those questions, then boy do we have the project for you! [Lou Wozniak] has an awesome tutorial for building an apple cider press using a ceiling fan motor and a handful of items available at your local hardware store.
The build is pretty simple in concept but complex in execution, and [Lou] does a fantastic job of covering every step in detail in his two project videos. The project has two main components: the grinder to decimate the apples and create a juicy, pulpy soup, and the press to extract the juice. The grinder is powered by the fan motor, while the press uses a screw-drive connected to a power drill, and then a ratchet to squeeze out every last drop.
Eager for more ceiling fan motor goodness? You’re in luck! Apparently [Lou] is a master of repurposing fan motors, and we featured a pottery wheel he made with one a while back.
Continue reading “Apple Cider Press Is Just In Time For Fall”
Doubling Down On A Big LED Display
Last year at the 2014 NC Maker Faire, Manical Labs brought a large LED display. Blinking LEDs and pixel animations are always welcome, but at 24 inches square this build was impressive, but it wasn’t impressive enough. This year, [Adam] at Manacal Labs wanted to go bigger. Much bigger. This build is called Colossus, and at two square meters and with 1250 individual LEDs, this LED display is a colossal build.
When building a big LED display, an enormous amount of planning pays off in dividends. The backbone of this project is a sheet of 3/8″ plywood, ripped down to 1 meter by 2 meters. 1250 half-inch holes are drilled in this sheet over four or five very long and very tedious evenings. The LEDs are installed in the thousand or so holes, and a grid of foam core board encases each individual LED.
One of the biggest problems with large arrays of LEDs is the sheer scale of it all. If one LED pixel draws 60mA, 1250 pixels means a draw of 75 Amps. This current will melt most wires, so the power is delivered over custom made copper bus bars. Driving this display with a reasonable refresh rate is another important consideration; WS2812 lights, with an 800kHz signal over one wire, is far too slow for a huge display. Instead of the 2812s, [Adam] went with LPD8806 LEDs that can be clocked at 30MHz. This is controlled with two AllPixels, effectively making this two displays acting as one. It all comes together in a very big LED display. You can check out a video of it below.
Continue reading “Doubling Down On A Big LED Display”
