Hack A Padlock Key From Plastic Scraps
Not too many years ago, if you wanted a decent copy of a key made, you had to head to either a locksmith’s shop or the nearest hardware store, where real people actually knew their trade. Now we generally take our keys to the Big Orange Box o’ Stuff and have it copied by a semi-automated machine, or even feed it into one of the growing number of fully automated key-copying kiosks, with varying results. But as [BlueMacGyver] shows us, a serviceable padlock key can be whipped up quickly at home with nothing but scraps.
The video below details the process – soot the profile of the key with a lighter, transfer the carbon to some stiff plastic with Scotch tape, and cut out the profile. With a little finagling the flat copy makes it into the lock and opens it with ease. Looks like the method could be applied to locks other than padlocks. As for raw material, we think we’ve found a use for all those expired credit cards collecting in the desk drawer.
We’ve given a lot of coverage lately to hacks involving locks, including copying keys from photos and making bump keys with a 3D printer. But we like this hack for its simplicity. True, you need physical access to the key to copy it, and that limits the hack’s nefarious possibilities. But maybe that’s not such a bad thing.
[Thanks, Mike]
11 thoughts on “Hack A Padlock Key From Plastic Scraps
  1. My exact first thoughts were along the same lines as previous comments: Now try that with something other than a Master padlock.
    Apart from that, Hackaday itself already featured methods of retrieving keying info from images of a key. Once you know the keying code it’s not that hard to make a key copy out of ANY material.
  2. When I was crazy about locksmithing and lock-picking decades ago there were those clam-shell things with clay or something that you made a mold with by pressing then filled with pewter or wax or whatever..
    There is also using a blank and cigarette lighter and file, but the key-blade id system in the lock-smith trade is pretty stupid and idiotic..
Leave a Reply to mythgarrCancel reply
