Planespotter Spots Planes, Tracks Destinations
Ever looked up in the sky and wondered where all of those planes above you were going? [squix] no longer has to, thanks to his ESP8266-based Planespotter.
He built this nifty device to grab the details of the flights he sees taking off from Zurich airport. It’s a neat build, running on an ESP8266 that receives ADS-B data from ADS-B Exchange. This service allows you to query the ADS-B data with a specific location.
[squix]’s plane tracker sends a query to ADS-B exchange for flights in his location and below a certain height (so he sees ones that are just taking off), then displays the received information on the OLED screen. He says a display-only version will run you around $20, while the full version that also receives and shares data with the ADS-B Exchange will cost you about $50. That’s a lot cheaper than a plane ticket…
11 thoughts on “Planespotter Spots Planes, Tracks Destinations
    1. Thank you, just filled a bugreport for the automated HaD article-generator. It’s quite good but still not perfect.
      (This is a joke of course, i am not Richard Baguley.)
Leave a Reply to Antron ArgaivCancel reply
