Teardown A Classic : Tektronix P6042 Current Probe
[Paul Rako]’s teardown of his treasured P6042 current probe shows why Tektronix commands so much respect among the old hats of the electronics world.
Built in 1969, the P6042 is pretty sparse transistor-wise when compared a modern sensor. The user would clip the current probe, permanently attached to the case since the circuit was tuned for each one, over a wire and view the change in volts on an oscilloscope. When the voltage division on the oscilloscope was set properly the current in a circuit could be easily seen.
The teardown is of a working unit so it’s not completely disassembled, but it also sits as a nice guide on refurbishing your own P6043, if you manage to snag one from somewhere. Aside from capacitors and oxidized switch contacts there’s not much that can go wrong with this one.
As for how it compares, the linear power supply, analog circuit design, and general excellent engineering has the P6042 coming in with a cleaner signal than some newer models. Not bad for a relic! Do any of you have a favorite old bit of measurement kit?
6 thoughts on “Teardown A Classic : Tektronix P6042 Current Probe
Leave a Reply to DainBramageCancel reply
