Well, That Was Quick: Heng Lamp Duplicated
That didn’t take long at all! We covered a pretty cool lamp with a novel magnetic switch mechanism, and [msraynsford] has his version laser cut, veneered, a video posted on YouTube (embedded below), and an Instructable written up before we’d even caught our breath.
For those who missed it, the original Heng lamp is a beautiful design with a unique take on a magnetic switch. As with the original, the secret sauce is a switch inside that’s physically held closed by the two magnets. It’s a pretty clever mechanism that looks magical to boot.
[msraynsford]’s version replaces the floating spheres with floating cylinders, which are easier to fabricate in layers on a laser cutter, but otherwise the copy is fairly true to the aesthetics of the original. Pretty sweet!
Thanks [Adrian] for the great tip!
20 thoughts on “Well, That Was Quick: Heng Lamp Duplicated
  1. Remind me again why this is better then a simple on/off switch? OK – granted it’s different, and maybe you can even claim it’s a “work of art, not just a lamp” – fine I get that. But there is strong vibe of 1989 “Sharper Image” catalog I-don’t-need-it-I-just-want-other-people-to-know-I-have-it vibe. Cudos to the [msraynsford] – it does look well executed!
    1. “Remind me again why this is better then a simple on/off switch? OK – granted it’s different, and maybe you can even claim it’s a “work of art, not just a lamp” – fine I get that. But there is strong vibe of 1989 “Sharper Image” catalog I-don’t-need-it-I-just-want-other-people-to-know-I-have-it vibe.”
      Translation:
      I wish I’d thought of it but I didn’t so I’m just going to behave like a spoilt teenager.
  2. Cool project, but I don’t like that string on the bottom bit. Would it be possible to instead use a magnet and put something in the top cylinder to turn it into a reverse levitating magnet? So that way you just lift it into the general vicinity and it just floats there until you move it away?
        1. … And then remove the magnetic puck gimmick on a string….
          …. Instead:
          Poke your finger thru the open frame to toggle the lamp on and off.
          Bonus: Move your finger up and down to change intensity.
          Bonus, bonus: Slide finger left and right to change color.
          Etc
  3. Love the fact that it is admittedly a ripoff design that the copier has now shown everyone else how to do it. to make one for yourself is one thing, but i would imagine that the designer might be sort of pissed off now that someone else has made it so that everyone can do it without having to do the legwork themselves…
    1. I disagree, but will give you a +1 for that loose-leaf tea steeper thing that I now want to purchase.
      I figure if someone sees that homemade one and want it, most people are going to just buy the original version.
      Imitation is the sincerest form of flattery
Leave a Reply to notarealemailCancel reply
