Hackaday Prize Entry: OLED Displays For Soldering Iron Tips
Soldering pen with OLED display
Having soldered one end of a wire to a switch, you move on to the next step in your hack, soldering the other end of the wire to the more temperature sensitive pin 11 on the 6847 video chip. You set the soldering pen’s target temperature to something lower. You position the end of a tinned wire just so, with the solder held between the ring and pinky fingers of the same hand. You stare hard at the pin while you still know which one it is. Luckily this soldering pen has a display in the handle, close enough for you to glance at it quickly and see that the target temperature has been reached. You solder the wire in place.
The previous hack was one I did back in 1982 to my TRS-80 color computer but alas, there was no display in the soldering pen’s handle. I was just too early for the sweet soldering pen that [vlk] is making, and has entered into the 2017 Hackaday Prize.  It’s powered by a LiPo battery and can go from 25 to 400℃ in 5 seconds. The handle contains the electronics, including an STM32F031, and we’re impressed with how small he’s managed to get it all. Two buttons provide control and an OLED display simultaneously shows what looks like two target temperatures, the current temperature, voltages, battery charge level, and status. And if you want to make your own, his page even includes the schematics. Watch how easy it is to use in the videos below the break.
While [vlk]’s soldering pen has all the precision and ease of use you’d want, check out what is probably the simplest approach to soldering iron temperature control we’ve seen here. Or you could go for something in between, this one that’s also powered by LiPo batteries but has the display in a small laser cut box.
33 thoughts on “Hackaday Prize Entry: OLED Displays For Soldering Iron Tips
          1. You can also skip it. My soldering station does not have one. It detects the iron not being used by the amount of power required. First it decreases the temperature to 250 (after about 5 minute), but you can wake it up by trying to solder and it is back up in a 5 seconds, won’t even see it. Then it goes down to 50 after a while (30 minutes?) if unused. To wake it back up you press any button.
            I think it is better than accelerometer because it avoids turning ON by itself in case of motion or accidental motion (ex standing up from the desk am moving things around).
        1. Good to know. I have a couple USB types and they are OK for small tasks. And a pair of the TS100 which I have only tested (bought with a 12V PSU). I have some Turnigy batteries I will have to try with them.
        1. But it already got cheaper since I bought mine – I paid around €50. But it’s really nice. It works with 12V but with quite a low power (~17W), so I use it with a Laptop car adapter to convert the 12V from a solar/battery system to 24V for good power. With a 19V supply from an (old) laptop it also works quite good.
    1. Or perhaps you have no clue? Temperature sensitive parts benefit from using the lowest temperature possible that gets the solder joint to wet properly with a reasonable application time. Higher temperatures mean greater thermal stress.
      1. Yeah. With a high enough power, good enough temperature regulation and proper tip for a purpose, there wouldn’t be much need for raising the temperature for bigger parts either.
        But with the typical realities in life, adjusting the temperature to compensate the amount of heat energy needed is a simple hack that works.
  1. Just remember that switching power supplies have capacitors between the output and mains and that sometimes the output might float at a very different voltage then expected.
    So a strong suggestion is to make sure the tip is grounded properly, not shorted to ground, but through a resistor to limit the current.
    1. Yea, the better stations usually have a switch or plug-in option to allow your tip to either be completely floating, hard-earth, or earth-connected over 1MOhm, depending on your application. The 1MOhm to earth is pretty much the standard option for most applications tho.
    1. Well, you can get the 0.91″ OLED displays for less than half the price, but they are a bit taller in the narrow dimension (12mm vs 9mm). They are also significantly higher resolution (128×32 vs 96×16), though that probably doesn’t matter much for this application.
Leave a Reply to notarealemailCancel reply
