A Switched Game Boy Advance SP
After Nintendo’s wild success with the Wii U, Nintendo released it’s Nintendo Switch. The switch functions primarily as a home console, stagnantly connected to a display. However, Nintendo switched things up a bit: the Switch can be removed from its dock for standalone tablet-like use. But there’s a slight problem: when the Switch is in portable mode, it leaves behind a bleak and black box. What’s one to do? Worry not: [Alexander Blake] is here to save the day with a Game Boy Advance SP and an X-Acto knife.
After casually noting that the main control board of the Switch was roughly Game Boy Advance SP sized, [Alexander Blake], aka [cptnalex], knew it was meant to be. After retrieving his broken Game Boy Advance SP from his closet, [cptnalex] set to work turning his Game Boy into a Nintendo Switch dock. When he was done, the results were stunning, especially considering the fact that this is his first console mod. Moreover, the very fact that he did it all with an X-Acto knife rather than a Dremel is astounding.
With the screen providing support to the Switch, [cptnalex’s] design leaves some to be desired for long term use. But we know for sure that [cptnalex’s] design does, in fact, work. Due to naysayers of the internetTM, [cptnalex] filmed a video of his dock in uses (embedded after the break). But, what the design lacks in structural stability, it more than makes up for in aesthetics. On the device itself, [cptnalex’s] history with controller painting shines through.
If you want to see more of [cptnalex’s] work, you can follow him on Instagram. For more console mods that will take your breath away, look no farther than [Bungle’s] vacuum formed portable N64.
10 thoughts on “A Switched Game Boy Advance SP
  1. Minor correction, he’s using a gameboy advance SP as a dock for the Switch so this:
    “After casually noting that the main control board of the Switch was roughly Game Boy Advance SP sized”
    Isn’t quite right, maybe the main control board of the Switch’s *dock* is the right size, but not the switch itself.
      1. Alternative facts lol.
        “This Gamekid is tremendous. Sonic the Hedgehog is going to make us great again. Super excited to catch them all. So amazing”
        Pretty cool build though :)
Leave a Reply to ???? (@samwhiteUK)Cancel reply
