Hackaday Prize Entry: Heart Failure Detection Device
Early and low-cost detection of a Heart Failure is the proposal of [Jean Pierre Le Rouzic] for his entry for the 2017 Hackaday Prize. His device is based on a low-cost Doppler device, like those fetal Doppler devices used to listen an unborn baby heart, feeding a machine learning algorithm that could differentiate between a healthy and an unhealthy heart.
The theory behind it is that a regular, healthy heart tissue has a different acoustic impedance than degenerated tissue. Based on the acoustic impedance, the device would classify the tissue as: normal, degenerated, granulated or fibrous. Each category indicates specific problems mostly in connective tissues.
There are several advantages to have a working device like the one [Rouzic] is working on. To start, it would be possible to use it at home, without the intervention of a doctor or medical staff. It seems to us that would be as easy as using a blood pressure device or a fetal Doppler. It’s also relatively cheap (estimated under 150$) and it needs no gel to work. We covered similar projects that measure different heart signals, like Open Source electrocardiography, but ECG has the downfall that it requires attaching electrodes to the body.
One interesting proposed feature is that what is learn from a single case, is sent to every devices at their next update, so the devices get ‘smarter’ as they are used. Of course, there are a lot of ways for this to go wrong, but it’s a good idea to begin with.
Hackaday Prize Entry: Underwater Glider Offers Low-Power Exploration
[Alex Williams] created his Open Source Underwater Glider project as an entry to The Hackaday Prize, and now it’s one of our twenty finalists. This sweet drone uses motor-actuated syringes to serve as a ballast tank, which helps the glider move forward without the use of traditional propellers.
Unlike most UAVs, which use motors to actively move the craft around, [Alex]’s glider uses the syringes to change the buoyancy of the craft, and it simply glides around on its wings. When the craft starts getting too deep, the syringes push out the water and the glider rises toward the surface until it’s ready for another glide.
This low-power solution allows for long-term science projects and research. In addition to conserving power, the glider’s slow travel does not disturb the water or sea life.
[Alex]’s goal is to make his glider open source and 3D printable, combined with off-the-shelf hardware and ArduSub under the hood.
Continue reading “Hackaday Prize Entry: Underwater Glider Offers Low-Power Exploration”
Hackaday Prize Entry: Rangefinder + Camera = SmartZoom
The interesting thing about submissions for The Hackaday Prize is seeing unusual projects and concepts that might not otherwise pop up. [ken conrad] has a curious but thoughtfully designed idea for Raspberry Pi-based SmartZoom Imaging that uses a Pi Zero and camera plus some laser emitters to create a device with a very specific capability: a camera that constantly and dynamically resizes the image make the subject appear consistently framed and sized, regardless of its distance from the lens. The idea brings together two separate functions: rangefinding and automated zooming and re-sampling of the camera image.
The Raspberry Pi uses the camera board plus some forward-pointing laser dots as a rangefinder; as long as at least two laser dots are visible on the subject, the distance between the device and the subject can be calculated. The Pi then uses the knowledge of how near or far the subject is to present a final image whose zoom level has been adjusted to match (and offset) the range of the subject from the camera, in effect canceling out the way an object appears larger or smaller based on distance.
We’ve seen visible laser dots as the basis of rangefinding before, but never tied into a zoom function. Doubtlessly, [ken conrad] will update his project with some example applications, but in the meantime we’re left wondering: is there a concrete, practical use case for this unusual device? We have no idea, but we’d certainly have fun trying to find one.
Hackaday Prize Entry: WiFi ePaper
[Frank Buss] designed an electronic version of a sticky note: a WiFi enabled, solar-powered ePaper, with magnets embedded in the casing. It’s based on the new ESP32, and the idea is that you can update it via your smart-phone or over the internet via a cloud app to show any message you want. Being an ePaper display, the power consumption is greatly reduced, at least if you are cautious using the ESP32.
The final version plans to poll a server once per hour to get a new image to display. Depending on the final size and battery constraints, our guess is that it could probably poll often. Of course, that depends on the available charging light, which is usually reduced when you are inside the house. The project also has 3 buttons to provide user input, which can be customized for a wide array of actions, as [Frank Buss] notes:
For example install it on the fridge of your grandma, who might not be very proficient in using modern internet connected devices. Then you can send her birthday wishes, or remind her of schedules. And the buttons could be used as a feedback channel, like confirming a date. Or when installed at a public place, it can act as a bulletin board. Or it can be used for a modern form of internet connected graffiti or other art projects. The possibilities are infinite.
This project immediately reminds us of the recent SHA2017 badge we covered some days ago, with a bigger display and solar panel or the e-ink wifi display project from last year.
The latest version is being tested with a black/white/red ePaper display, as we can see in the video:
Continue reading “Hackaday Prize Entry: WiFi ePaper”
Hackaday Prize Entry: A PC-XT Clone Powered By AVR
There is a high probability that the device on which you are reading this comes somehow loosely under the broad definition of a PC. The familiar x86 architecture with peripheral standards has trounced all its competitors over the years, to the extent that it is only in the mobile and tablet space of personal computing that it has not become dominant.
The modern PC with its multi-core processor and 64-bit instruction set is a world away from its 16-bit ancestor from the early 1980s. Those early PCs were computers in the manner of the day, in which there were relatively few peripherals, and the microprocessor bus was exposed almost directly rather than through the abstractions and gatekeepers we’d expect to see today. The 8088 processor with an 8-bit external bus though is the primordial PC processor, and within reason you will find software written for DOS on those earliest IBM machines will often still run on your multiprocessor behemoth over a DOS-like layer on your present-day operating system. This 35-year-plus chain of mostly unbroken compatibility is both a remarkable feat of engineering and a millstone round the necks of modern PC hardware and OS developers.
Those early PCs have captured the attention of [esot.eric], who has come up with the interesting project of interfacing an AVR microcontroller to the 8088 system bus of one of those early PCs. Thus all those PC peripherals could be made to run under the control of something a little more up-to-date. When you consider that the 8088 ran at a modest 300KIPS and that the AVR is capable of running at a by comparison blisteringly fast 22MIPS, the idea was that it should be able to emulate an 8088 at the same speed as an original, if not faster. His progress makes for a long and fascinating read, so far he has accessed the PC’s 640KB of RAM reliably, talked to an ISA-bus parallel port, and made a CGA card produce colours and characters. Interestingly the AVR has the potential for speed enhancements not possible with an 8088, for example it can use its own internal UART with many fewer instructions than it would use to access the PC UART, and its internal Flash memory can contain the PC BIOS and read it a huge amount faster than a real BIOS ROM could be on real PC hardware.
In case you were wondering what use an 8088 PC could be put to, take a look at this impressive demo. Don’t have one yourself? Build one.
Hackaday Prize Entry: Customizable Linear Actuators
The current state of robotics, 3D printers, and CNC machines means any shade tree roboticist has the means to make anything move. Do you want a robotic arm? There are a dozen designs already available. Need an inverted powered pendulum? There are a hundred senior projects on that every semester. There is, however, one type of actuator that is vastly underutilized. Linear actuators aren’t ‘maker’ friendly, and building a customized linear actuator is an exercise in pain.
A die for aluminum extrusion
For their Hackaday Prize entry, the folks at Deezmaker are changing the state of linear actuators. They’ve created ‘Maker Muscle’, a linear actuator that’s fully customizable to nearly any length, power, speed, motor, or any other spec you could think of.
There were a few design goals for Maker Muscle. It must be modular, customizable, low-cost, and must allow for a lot of mounting options for use with t-slot aluminum extrusion. The answer to this is a completely custom aluminum extrusion. Basically, the motor mounts at one end, the actuator itself pokes out the other, and you can mount this device via the t-slot tracks around the edge of the extrusion. Think of it as the linear actuator version of MakerSlide, except instead of using this extrusion in CNC machines, it’s designed for moving shafts back and forth.
Already, Deezmaker has a working prototype and they’ve already moved onto a Kickstarter campaign for Maker Muscle. It’s a great idea, and we can’t wait to see what this neat product will be used for. You can check out a short demo video of Maker Muscle in action below.
Continue reading “Hackaday Prize Entry: Customizable Linear Actuators”
Hackaday Prize Entry: HeartyPatch
[Ashwin K Whitchurch] and [Venkatesh Bhat] Have not missed a beat entering this year’s Hackaday Prize with their possibly lifesaving gadget HeartyPatch. The project is a portable single wire ECG machine in a small footprint sporting Bluetooth Low Energy so you can use your phone or another device as an output display.
Projects like this are what the Hackaday Prize is all about, Changing the world for the better. Medical devices cost an arm and a leg so it’s always great to see medical hardware brought to the Open Source and Open Hardware scene. We can already see many uses for this project hopefully if it does what’s claimed we will be seeing these in hospitals around the world sometime soon. The project is designed around the MAX30003 single-lead ECG monitoring chip along with an ESP32 WiFi/BLE SoC to handle the wireless data transmission side of things.
We really look forward to seeing how this one turns out. Even if this doesn’t win a prize, It’s still a winner in our books even if it only goes on to help one person.
