posted Mar 2nd 2009 12:19pm by
Eliot
filed under:
macs hacks,
misc hacks,
pcs hacks
Many of our cherished computers and consoles from the past have not stood up well over time. It’s not the hardware as much as the color. From Commodores, Apples, to Super Nintendos, the machines have slowly drifted towards a sickly yellow and even brown. The culprit appears to be the fire retardant chemicals used in the plastics. Amiga enthusiasts have spent the last year perfecting a technique that restores the plastic of these machines to its original splendor. Dubbed ‘Retr0brite‘ it’s a gel made from hydrogen peroxide, xanthan gum, glycerine, and ‘Oxy’ style laundry booster. The results are really impressive. If you do start restoring your own machines, caution should be used since it requires strong concentrations of hydrogen peroxide typically employed in bleaching hair.
[via Waxy]
posted Jan 26th 2009 7:00pm by
Eliot
filed under:
misc hacks,
tool hacks
[ladyada] has republished an interesting snippet from the synthDIY mailing list. [David Dixon] discusses the actual chemistry behind ferric chloride based home circuit board etching. He concludes that ferric chloride is essentially a ‘one-shot’ oxidant. It can’t be regenerated and can be difficult to dispose of properly. The use of acidified copper chloride is a much better path and becomes more effective with each use, as long as you keep it aerated and top up the acidity from time to time. This etchant solution is actually the result of initially using hydrogen peroxide as an oxidant along with muriatic acid. You can see us using this solution in our etching how-to and while creating the board for our RGB lock. For more information on using hydrogen peroxide, check out [Adam Seychell]‘s guide and this Instructable.
Aside: [ladyada] has added the receiver code to the Wattcher project page.
