Vintage Video Projector Lives Again
Projectors are getting a lot less expensive these days, what with China pumping out Pico projectors by the boat load and all. But did you know it’s not that hard to convert an old slide projector to digital? [Alec Smecher] shows us how with a 1950’s LaBelle 75 slide projector, and the result is pretty awesome.
dmd_chipDigital projectors can use a few different technologies to work. The best, and brightest is DLP (Digital Light Processing) by Texas Instruments — which is pretty well the world-wide standard for high-end, high-lumen digital projection. It works by bouncing red, green, and blue light off of three DMD’s (Digital Micromirror Devices) which have an array of tiny 2-position mirrors, with each representing a pixel.
One of the older technologies is LCD, which is even easier to understand. You shine white light through a color LCD, and there is your projection. All you need for a projector, then, is an LCD, a light source, and a bit of optics.
Continue reading “Vintage Video Projector Lives Again”
