The 2009 ShmooBall gun
posted Feb 6th 2009 8:15am by
filed under: cons, security hacks
larry
The registration desk hasn’t opened yet at ShmooCon 2009, but we’re already running into old friends. We found [Larry Pesce] and [Paul Asadoorian] from the PaulDotCom Security Weekly podcast showing off their latest ShmooBall gun. ShmooBalls have been a staple of ShmooCon from the very beginning. They’re soft foam balls distributed to each of the attendees who can then use them to pelt the speakers when they disagree. It’s a semi-anonymous way of expressing your dismay physically. [Larry] has been building bigger and better ways to shoot the ShmooBalls for the last couple years. You may remember seeing the 2008 model. This year the goal was to make the gun part much lighter. The CO2 supply is mounted remotely with a solenoid valve and coiled air line. The pistol grip has a light up arming switch and trigger. The gun is fairly easy to transport: the air line has a quick disconnect and the power is connected using ethernet jacks.
DIY RFID implant
posted Oct 15th 2008 4:44pm by
filed under: lifehacks, misc hacks, wireless hacks
[Quethe] implanted an RFID chip into his hand so that he can access his handgun safe without having to fumble around for keys or buttons. He’s also planning to do more with the chip, including installing readers so he can access his car without keys. [Quethe] claims that inserting the chip hurts less than drawing blood. From the video he’s apparently using livestock grade equipment for the injection. While we applaud his ingenuity, we’re not sure that the convenience of easier access to guns and cars is actually worth the trouble of putting a chip in your body.
We’ve covered quite a a few hackers that have chosen to chip themselves in the past. [Mikey Sklar] did it back in 2005 after constructing a pair of pants to block the signal. [Amal Graafstra] ended up writing RFID Toys after implanting himself. [Larry Pesce] from the PaulDotCom podcast had his chip cloned on stage by [Major Malfunction] at ShmooCon. [Annalee Newitz] had her chip cloned by [Jonathan Westhues] while covering RFID hacking for Wired. It’s interesting to see the practice of DIY RFID chipping gaining traction, and, thankfully, all of the people just listed understand that it’s not a form of security.
[via Boing Boing]
Hack a Day serves up fresh hacks each day, every day from around the web as well as hacking related news.
Send us your hacks
Hacks
Resources
