posted Jun 16th 2009 10:44am by
Eliot Phillips
filed under:
macs hacks,
netbook hacks,
pcs hacks
A friend recently commissioned us to install OSX on a netbook. We advised him to purchase the Dell Vostro A90. It’s essentially a rebadged Dell Mini 9, a model that has been discontinued, but is well suited for OSX. It’s only available with a 1.6GHz Atom processor, 1GB RAM, and 16GB SSD. Depending on what deals are available, it’s $250-$300. We also had him purchase a 2GB stick of RAM which is the upper limit supported by the BIOS. Read the rest of this entry »
posted Feb 21st 2009 2:40pm by
Eliot Phillips
filed under:
laptops hacks,
macs hacks,
netbook hacks,
pcs hacks
Installing OSX on commodity PC hardware has advanced a lot since the early days of OSx86 when Apple switched to Intel. With the advent of netbooks, a new target platform has emerged; one that doesn’t have an official Apple equivalent. The small subset of models means that it’s easy to find someone else that has the same machine as you, but it still takes some forum walking to bring all the pieces together. Gizmodo has done this and compiled a comprehensive guide for the Dell Mini 9. The Mini 9 is a very nice machine and according to Boing Boing Gadgets’ chart, one of the most compatible with OSX. Earlier this week you could purchase a new one for just $200.
For Gizmodo’s install, they used a Leopard retail DVD with [Type11]’s bootloader. They’re breaking the EULA, but at least it’s not piracy. They had to use both a DVD drive and a USB hard drive because device recognition was flakey. Despite this, the actual install process doesn’t appear to be too difficult. They say all the hardware works, “The Mini 9 is a beautiful OS X machine.” Check out this Hackit to learn about netbook OSX experiences from other Hack a Day readers.
posted Sep 6th 2008 10:59am by
Joey Celis
filed under:
laptops hacks,
netbook hacks,
pcs hacks
One of the things that made the original Asus Eee PC such a big success was the ability to add almost anything you wanted to it. While this might not have anything to do with Dell releasing a service manual showing you how to disassemble your brand new Mini 9, we’re not gonna fault them for making one available.
The service manuals show the proper way to gain access to the various parts of the Mini 9 right down to the motherboard itself. It’s nice to know that the Mini 9 isn’t locked down where simple things like replacing the RAM or upgrading to a larger SSD won’t void your warranty.
[via jkkmobile]
