posted Jan 26th 2009 9:38am by
Ian
filed under:
parts,
peripherals hacks
posted Oct 20th 2008 7:15am by
Ian
filed under:
classic hacks,
misc hacks,
parts
DIP through-hole chips are an old package with instantly recognizable dual in-line pin rows. Beginners love these chips because they’re large and look easy to solder; we abhor them because we hate messing around with the drill. Whatever your motivation for using a through-hole chip, use a socket whenever possible. A circuit board with socketed chips is easy to test without endangering the parts, and ICs can be removed, tested, and replaced, without resorting to a soldering iron. This week, by request, we looked at several common through-hole chip sockets. Read the rest of this entry »
posted Sep 22nd 2008 12:24pm by
Ian
filed under:
classic hacks,
misc hacks,
parts
Every project needs a power supply. As 3.3volt logic replaces 5volt systems, we’re reaching for the LM317 adjustable voltage regulator, rather than the classic 7805. We’ve found four different hobbyist-friendly packages for different situations.
A simple voltage divider (R1,R2) sets the LM317 output between 1.25volts and 37volts; use this handy LM317 calculator to find resistor values. The regulator does its best to maintain 1.25volts on the adjust pin (ADJ), and converts any excess voltage to heat. Not all packages are the same. Choose a part that can supply enough current for your project, but make sure the package has sufficient heat dissipation properties to burn off the difference between the input and output voltages.
