WordPress 2.7 upgrade in one line
posted Dec 10th 2008 7:46pm by Eliot Phillips
filed under: downloads hacks, misc hacks
wordpress
BadPoetry WordPress 2.7 has just been released and features a complete interface overhaul. Hack a Day runs on WordPress MU hosted by WordPress.com, so we got this update last week. We run standard WordPress.org on all of our personal blogs though. We recommend it because it’s free, has a massive userbase, and if you host it yourself, you can do whatever you want with it.
To make the upgrade process as simple as possible (and for the sheer rush of ‘rm -rf’), we use a one line command.
$ curl http://wordpress.org/latest.zip -o "wp.zip" && unzip wp.zip && rm -rf ./wordpress/wp-content/ && cp -r ./wordpress/* ~/www/
curl downloads the latest version from wordpress. unzip unpacks all of the files into a directory called ‘wordpress’. rm -rf removes everything in the ‘wp-content’ directory. Otherwise, you will overwrite your images, themes, and plugins. cp -r copies everything to your http document root, overwriting the previous install.
Naturally, you should back up your current install and database beforehand. We tend to use the one-liner with reckless abandon. If you’re wondering about the terseness, it was designed to fit inside the 140 character limit of Twitter.
[Thanks, Chris Finke]
How to destroy a filesystem
posted Nov 9th 2008 4:00pm by Eliot Phillips
filed under: android hacks, g1 hacks, pcs hacks, security hacks
rmrf
The G1 ‘execute every command you type‘ bug naturally spawned ‘rm -rf /’ jokes. rm is the Linux command for deleting files. The -r and -f flags will cause it to remove files recursively and ignore confirmation. Executed as root it will annihilate the entire filesystem. Won’t it? [Jon Hohle] decided to test exactly how destructive the command was to *nix systems. How functional would the system be afterwards? He tested it side by side with the Windows equivalent, both ‘format c:’ and ‘del /F /S /Q’. He wanted to see what protections were available and what would be left working. Linux ended up completely broken while Windows, thanks to file locking, actually shutdown cleanly… and never came back. Some OSes, like Solaris, refuse to run the command ‘rm -rf /’ to prevent accidents.
Hack a Day serves up fresh hacks each day, every day from around the web and a special How-To hack each week.
Send us your hacks
