Manpowered PVC Rollercoaster
Swing sets and jungle gyms are good enough for your average back yard. But if you want to go extreme you need to build your own backyard roller coaster.
This impressive offering uses PVC pipe for the rails. At its tallest it stands 12 feet, using pressure treated 4×4 lumber as the supports. Pressure treated spacers span the tracks, … Read the rest
Roller coaster simulator for the Redbull creation contest
[Dave] and [Martin], otherwise known as Ballistic Locomotive, sent in their entry for the Redbull creation contest. It’s a roller coaster simulator that can emulate the twists, turns, and drops of a roller coaster in your living room.
The simulator is built around a plywood roller coaster car mounted on a 2 DOF table. With a few first-person roller coaster … Read the rest
Entrust you kid’s life to a homemade roller coaster?
So you fancy yourself as an amateur engineer? Been working on those welding skills for a while? The real test is to trust your children’s lives on a roller coaster you’ve designed and built (translated).
Now we’re not talking some tired old carnival ride like the teacups. This is a full-blown roller coaster, complete with an upside-down loop. … Read the rest
