6502 Retrocomputing Goes To The Cloud
In what may be the strangest retrocomputing project we’ve seen lately, you can now access a virtual 6502 via Amazon’s Lambda computing service. We don’t mean there’s a web page with a simulated CPU on it. That’s old hat. This is a web service that takes a block of memory, executes 6502 code that it finds in it, and then returns a block of memory after a BRK opcode or a time out.
You format your request as a JSON-formatted POST request, so anything that can do an HTTP post can probably access it. If you aren’t feeling like writing your own client, the main page has a form you can fill out with some sample values. Just be aware that the memory going in and out is base 64 encoded, so you aren’t going to see instantly gratifying results.
Continue reading “6502 Retrocomputing Goes To The Cloud”
