Growing Copper And Silver Crystals For Art
Usually when Hackaday covers electroplating techniques, it’s to talk about through-hole PCB plating. But did you know you can use the same method to produce beautiful copper and silver crystal structures?
[Fred and Connie Libby] are kind enough to share how they make their crystals that they sell in tiny glass vials you can wear around your neck. The process is simple as you would think; it’s just an electrolyte solution, with a current passing through it, depositing the metal in an ion-exchange. Rather then stop once the part is sufficiently covered, you let the process run amok, and soon large crystal formations begin to emerge. [Fred and Connie] share their technique very briefly, so if you’re looking for a more detailed how-to guide, you can find one here.
Although silver crystals are a bit out of our budget, we wonder how large of a copper crystal could be grown? Large enough to be displayed on a coffee table? Surely such a work of art and science could be an interesting conservation piece in any hacker’s home.
