66% or better
Create a temporary phone number with inumbr
inumbr
Maybe you don’t want that one person that has barged into your life to know your private phone number? Could be a salesperson or a co-worker who you aren’t that impressed with, but have to get in contact with. Check out inumbr.
inumbr is a free online service that gives US users the ability to set up a unique phone number, have it forwarded to any number within the US and then have it set to expire without a trace when finished with it. The unique inumbr’s are never reused, and can be extended if longer terms are required. Users choose from a list of 22 area codes from major US cities like Chicago, Los Angeles and New York, select an expiry date and set a number that it should be forwarded to. When the term is up, the number is expired from the system, and never used again for any other user. If you wish to use the number at a later date, you can log into the inumbr system and reactivate it.
As we are becoming more and more mobile and security conscious, the desire for these types of services grows. A phone number can now be given out at will, with security and privacy remaining intact. Google Voice is a major player in this arena. A somewhat similar service, they allow for a unique number with voice mail to forward to other numbers at will, creating a masked or unidentified private number that can be used to give out to 3rd parties. inumbr makes this process simpler with the ability to cut off and reactivate numbers as desired.
