High Voltage: Build your own 84 kV lightning stick
posted Aug 24th 2011 6:00am by
filed under: toy hacks
There’s a proverb that says ‘Speak softly and carry a big stick’. Now that stick can come in a high-voltage form factor. The device above, which reminds us of a side-handled baton with a coke can stuck on the end, is a portable Van de Graaff generator.
Although debated in the comments, the creator of this hack claims you can shock someone with 84 kV of electricity using the device. Of course as a weapon it’s lacking since we’re talking about static electricity; the voltage can be through the roof but the current is extremely low. Despite that, there are some fun things you can do with them. The video after the break show it throwing off sparks with the lights dimmed. [Yardleydobon] also includes a few other tricks at the end of his tutorial. He makes a set of Franklin Bells using two more soda cans with the aluminum tab from one suspended in between them. As he charges it up, the tab dances back and forth, ringing the ‘bells’ it runs into. Once they are charged, the ringing can be restarted by discharging just one of the cans.
Read the rest of this entry »
900,000 volts at your fingertips
posted Dec 17th 2008 7:52am by
filed under: classic hacks, misc hacks
van_de_graaff
[Nickademuss] has put together these great instructions on how to build a 900,000 volt Van De Graaff generator. For those unfamiliar, Van De Graaff generators produce massive amounts of static electricity. They are usually the things you see in science centers that make people’s hair stand on end. [Nickademuss] put a lot of effort into this, he created 3D models and diagrams for many of the steps and gave a very detailed step by step breakdown.
Hack a Day serves up fresh hacks each day, every day from around the web as well as hacking related news.
Send us your hacks
Hacks
Resources
