3D Print In Wax, Cast In Metal
What does dry ice, ethonal, wax beads, and a blender have in common? It was the first attempts at making media for this wax 3D printer that [Andreas] has been building up. Wanting to produce 3D printed objects out of metal, and finding that direct metal laser sintering machines were still out of reach of reason, he set out to find a different way.
After trying a few different methods of making the powdered wax himself, he decided that it was much more time effective to just buy the stuff. Using the commercially available powered wax mixed with activated carbon, and a custom printer, the wax is blasted with a moderately high powered laser. More wax powder is applied over the freshly sintered layer, and the 3d part is built upwards. Once he has the part in wax, he can then make a mold of it and cast metal using the Lost Wax Casting method.
While the quality is not perfect, and you still need a roughly 2500$ laser setup (which was borrowed from his school) its surely a step into the future.
Join us after the break for a quick video.
[vimeo http://vimeo.com/29560030 w=470]
39 thoughts on “3D Print In Wax, Cast In Metal
    1. There’s a guy at london hackspace who has used foundry sand to make casts based from PLA printed parts.
      Essentially: print the part then press into foundry sand to create the negative and fill with casting material. It’s not perfect and I don’t know how adaptable it is but it produces some reasonable results
      1. That’s called “Standard Investment” if I am remembering my University Sculpture class correctly… of course… the less fancy name is probably “Sand Casting”… But either way, it’s a type of Investment Casting.
      1. It really depends on what he means by foundry sand. If you’re talking about greensand, (sand, clay, water, trace amounts of other stuff) you’re creating a negative mold that’s destroyed after you pour. A good setup can achieve 0.020″ accuracy… pretty good for a sand setup when that’s the average diameter of a grain of sand!
        The other method could be more like was mentioned with a “lost” process, where the plastic is consumed as the metal is poured. This sand is not bonded together, but rather just surrounds the lost object in a vessel. As was mentioned, residues can be an issue, but the bigger issue is the gas given off by the vaporising plastic. Compounds that give off relatively small amounts of gas are best, as they allow the metal to flow and fill the void quickly.
  1. Actually, regular additive 3d printing with plastic extrusion in layers might have produced as good or better result here. You can print parts on a standard Reprap Mendel type printer using PLA (polylactic acid) and use the same investment casting technique (“lost-PLA casting” I suppose in this case) :) Natural / undyed PLA vaporizes just like wax without residue.
  2. I didn’t realise that this was so new. I figured the rep-rap could handle wax lol. It definitely would drop the cost of lost wax casting.
    Mix this with a cheapish CNC mill and you have all kinda fabbing fun.
  3. “Ethonal”!?
    “It was the first attempts…”!?
    I wouldn’t normally comment on grammar or spelling mistakes, but you’ve ALL definitely been getting much worse recently. It’s become quite noticeable now.
    1. From the article …
      “One of the greatest drawbacks of this system is the cost of the lab-grade laser power supply that I used to power my IR laser. I was able to borrow an ILX Lightwave diode controller and power supply for the duration of the project. These devices cost between $1,300 and $2,500 used”
      I think we will be in agreement that a 100$ laser does little good without something to power it
      1. True, however a couple of amps to drive a diode is really not something that should be ‘cost prohibitive’ to any hacker who’s worth his salt.
        I realize this appears to be a university related project, but the description given here seems to indicate that the project isn’t worth it because you ‘have’ to buy $2500 in equipment. I was a bit misled by that statement, so I thought I’d ask. ;)
  4. I’ve watched some of his videos on vimeo, it would be nice if some non-time lapse were uploaded as I like to learn from watching something function, this is more like flipping through photographs.
    I like what he’s built, I’d like to try it myself.
    I’ll need a stronger laser…
    1. The laser’s not that expensive, the power supply is. He just uses a high end commercial power supply that he already had access to, instead of trying to buy/build one for cheap (which can be done, he even mentions that in his writeup). Really it’s hackaday’s poor writing skills that seem to imply it’s required.
  5. I like the water soluble PVA ideal. You would have to coat it with some casting mold compound that the water would not effect to wash it out. But you should be able to get great detailed parts if it washes out completely and easily too.
    1. I suspect that it’s difficult to generate true ‘powdered’ wax and get the right ratio of wax to carbon. I’m also guessing that the carbon serves the purpose of absorbing the IR laser radiation and generating heat.
      Which makes me wonder: Why not use a pulsed laser to control the spreading of heat? You can get range-finder YAG heads (pulsed) on eBay relatively cheap as well. The repetition rate (~10Hz) might be the rate limiting step however.
  6. Why not just use the wax in a normal 3-d printer, modified to use a lower temperature than used for plastic and a chilled print bed? Print the object directly as the plastic machines that use spools of plastic do, instead of the sintering process at all?
  7. The PVA from MAKERBOT is not a useable answer unless you are operating in a temperature/humidity controlled lab. The stuff absorbs so much moisture that it’s no good a couple days after you open the bag. I have a whole roll here that I can’t use. I was going to do lost PVA casting but it just won’t work. It is also very flexible and when you cast it in plaster the hydrostatic forces on the mold distort your original shape leaving you with a mess. I’m trying to build a new nozzle that uses wax.
  8. When using pva which has the problem of being water soluble, would painting the part after printing be a good way to form a waterproof barrier stop the part from melting or leeching into the investment plaster?
Leave a Reply to jewelrysolutionsCancel reply
