Toorcamp: The Tesla Gun
We discussed [Rob]’s Tesla Gun in the past. At that time, the build looked very impressive, but had not been fired yet. Fortunately, [Rob] got the device working and brought it to Toorcamp. He took the gun out every night and demoed the handheld Tesla Coil by having volunteers catch the streamers with a knife.
The gun uses a cordless drill battery for power, and a flyback transformer to generate the ~20,000 volts needed to drive the coil. The power electronics module was designed to be easy to replace, and [Rob] had extras at Toorcamp in case he burnt one up. [Rob]’s build log is very detailed, and definitely worth reading through. It explains how he cast the enclosure out of aluminium, built a custom porcelain high voltage switch, and designed the power electronics.
While this build should probably get a “do not try this at home” label, he definitely created something unique. We’re looking forward to when [Rob] shows the gun off next.
10 thoughts on “Toorcamp: The Tesla Gun
  1. Came here hoping to see a working version of a Warehouse Agent weapon by the same name. Not disappointed. :)
    It is a little larger than the version on the show, but still awesome.
  2. isn’t a terroid an awful top load to choose when directing the energy? i’ve seen one person who used a full size Tesla coil that directed it’s arcs through an acrylic tube with argon flowing through it.
Leave a Reply to steveCancel reply
