Recycled Foam Box Is Now A Weather Station
Raspberry pi in foam box
When [Ioannis] received some high resolution LCD’s in a tattered foam box, he posed to himself a most interesting question – Should he throw the foam box away, or use it as a container for a project? Fortunately for us, he decided on the latter and threw together a very capable weather station!
Having only an hour to spare, [Ioannis] grabbed a Raspberry Pi, WiFi USB stick and a camera module and went to work. He mounted the camera module to the foam lid using a highly advanced technique, and soldered a cable that would power the device directly to D17 – a Zener diode that sits on the bottom of the board.
For the weather data, he’s using another design of his – the Sensor Stick. This nifty device — which we featured over the weekend — is about the size of a stick of chewing gum, and sports an array of sensors including the popular BMP085, which can measure pressure and temperature .
He wraps up everything using open source software to get the data from the weather station. Pretty impressive for an old foam box and an hours time! This would be an interesting start to a home automation system. Connect it to motorized windows and/or a sprinkler system and he’s on his way to claiming The Hackaday Prize.
20 thoughts on “Recycled Foam Box Is Now A Weather Station
  1. Doesn’t insulating the (three) thermometers with Styrofoam kinda defeat the purpose of a weather station? other than that though, +1 for the upcycling of the box!
    1. Seeing he keeps the thing inside on the heater I guess it makes some,weird, sense :)
      And didn’t that sensor stick have a gyro and accelerometer? Maybe he should make a tremor and earthquake detector from it instead.
        1. Haha!!! Exactly! As I told, the position of the sensors is the recommended one! You will measure the heat of the RPi!
          I was not willing to do the epic weather station! I was willing to do something with the box!
  2. First… ANY insulating material is a potential source of ESD. Second, if it is all inside the box, just what is it going to flow through to get to ground?
    The world has become just a little ESD paranoid and the industry thrives on ignorance.
    1. Insulating means an electric charge cannot easily move along or through it. Thus you may have a region of the material that obtains a bigger charge than another region, even if the two are in the same contiguous piece of material. A conductive object placed between them (in this case, the Pi) provides an easier path for charge to flow and equalize than the material surface itself, so the charge flows through it. Bam, ESD, no ground path required.
      Paranoid? Nah. They just don’t want to incur the massive rework costs and customer dissatisfaction from early product failures. A little caution goes a long way.
Leave a Reply to justice099Cancel reply
