Careful Testing Reveals USB Cable Duds
What’s worse than powering up your latest build for the first time only to have absolutely nothing happen? OK, maybe it’s not as bad as releasing the Magic Smoke, but it’s still pretty bewildering to have none of your blinky lights blink like they’re supposed to.
What you do at that point is largely a matter of your troubleshooting style, and when [Scott M. Baker]’s Raspberry Pi jukebox build failed to chooch, he returned to first principles and checked the power cable. That turned out to be the culprit, but instead of giving up there, he did a thorough series of load tests on multiple USB cables to see which ones were suspect, with interesting results.
[Scott] originally used a cable with a USB-A on one end and a 3.5-mm barrel plug on the other with a switch in between, under the assumption that the plug on the Pi end would be more robust, as well as to have a power switch for the jukebox. Testing that cable using an adjustable DC load would prove that the cable was unfit for Pi duty, dropping the voltage to under 2 volts at a measly 500-mA load. Other cables proved much better under load, even those with USB mini jacks and even one with a 5.5-mm barrel. But the larger barrel-plug cable also proved to be a stinker when it was paired with an inline switch. In the video below, [Scott] walks through not only the testing process, but also gives a quick tour of his homebrew DC load.
The lesson is clear: not all USB cables are created equal, so caveat hacker. And if you’ve got a yen to check the cables in your junk bin like [Scott] did, this full-featured smart DC load might be just the thing.
[via Dangerous Prototypes]
29 thoughts on “Careful Testing Reveals USB Cable Duds
      1. I’ve got a little device called a “Charger Doctor” that I got on Amazon a few years ago (many other brands exist) that has USB A male and a USB A female connectors, it will read voltage and current. Of course without an adaptor, the voltage is read on the charger end, not taking voltage drop in the cable into account.I just checked, these adapters are a thing, I’ll have to buy some and test my cables.
  1. Somebody please punch me in the face if I’m spouting nonsense but … this looks like a really roundabout way to measure the cable resistance using an ohmmeter.
    I mean, let’s take his first cable, the horrible one. A voltage drop of 0.645V at 0.1A calculates to 6.45 Ohm, and the end of the test where the load gives out, a voltage drop of 4.223V at 0.654A calculates to … 6.45 Ohm. So it’s completely linear.
    Somebody CMIIW, I’ll happily stand corrected.
    1. Yup, multimeter is a good way, but add the connectors too! Also make sure to wiggle things around because crappy contacts are also very possible.
      I also think that once you put a low of current through the cable and the connector warms up things might change, so a long term test might also be good.
      People might not really know this, but usb connectors are designed so the cable one wears out while the device one stays intact, so that you replace the cheaper part.
      1. Yes, of course including the contact resistance involved all around. I guess my point was “current does not actually matter” as long as it’s below where it physically destroys the cable (or the connector) by turning it into a heating element. The curves he charts down at the end of the video seem to support this assumption.
      2. “People might not really know this, but usb connectors are designed so the cable one wears out while the device one stays intact, so that you replace the cheaper part.”
        Somebody should have told that to the designer of the Swampscum Galaxy 5S…
  2. I’ve had my share of USB cable power delivery problems, since we use USB to power the RGB Shades. Can’t use a thick USB cable because it’s difficult to wear. Eventually broke down and had custom power-only cables & overmolds made with thicker wires than the best USB cables but overall diameter still thinner and more flexible than a USB mouse cord.
  3. Walmart’s cheap ~ $6 USB cable is quite nice. Thick insulation and wires. The micro B connector latches in solidly and charge checking apps show it able to transfer the same power as the cable that came with my phone. I bought a 10 foot cable off eBay, nice looking with braided cover. The wires are so thin it can’t even pass 400ma. At least it was cheap.
  4. Very timely article.
    Recently my Nexus 7 would charge correctly while turned off, but the battery would actually *lose* charge if the tablet was switched on and in use even with the charger plugged in (though at a slower rate than if on battery only operation).
    Turns out those 99-cent store USB-A to Mini-USB cables are exactly what they are worth. The USB wire gauge was so thin, and hence the resistance so high, that the voltage drop between charger and tablet was sufficient that the charger wasn’t supplying enough juice to run the tablet itself (so the current necessary to make up the differnece was being drawn from the internal battery).
    Switching back to the original ASUS USB cable solved everything.
    1. Never buy 99 cent store crap. A friend was building a project and he needed some heavy gauge wire so he went to the 99 cent store and bought some jumper cables. When he cut off the ends he discovered the the fat wires were all insulation with a tiny wire inside. It’s hard to imagine that you could really jump a car with such a small wire.
      1. I needed to wire up data to a 1/8″ stereo plug.
        Rather than soldering 3 conductors to RadioShack plugs, I went to Dollar Tree and bought 3 sets of earbuds thinking, I just need to cut the ear buds off and I’ve already got wires soldered to the connectors I need.
        I cut off the first ear bud to find it was connect by two wires each smaller than 30 gauge!
      2. Also beware of buying wire on ebay. A lot of it is CCA, or copper clad aluminum. It’s dirt cheap and still fairly good value, but be aware that you need a thicker gauge for the same ampacity.
      3. I had a medium price USB extension cable but I needed another one, so I bought one at one of those super discount stores and it turned out to be better than the higher priced one.
        A think there is no real simple formula for buying stuff.
  5. In the defense of dollar store cables — it’s hit or miss. I’ve found some that were very good, in which case I cleaned out the store, and others that were crap. The only way to tell is to test them. The nice thing about a $.99 cable is, that even if it’s a good one, when it inevitably dies, you can throw it out without worry. Also, if it’s crap to begin with, it only costs you $.99 to find out.
  6. Doing work for a hardened computer company, we discovered that the (“budget”) over-molded SATA power connectors could sometimes retain solder paste that would conduct between pins within the overmolding. Some more than others, one unit caught fire! The lesson was to use the connectors with mechanically locked pins, not the overmolded ones.
  7. I’d love to see a tester (or more likely, multiple testers and/or smartphone apps) that will tell me everything I want to know about charging rates, data transfer rates, and protocols/standards supported for USB cables and devices. Suggestions, in addition to the above-mentioned USB Doctor?
Leave a Reply to William F. Dudley Jr.Cancel reply
