Repairs You Can Print: Fixing Pegboard Clips That Break Too Easily
Right now, we’re running the Repairs You Can Print Contest, where one lucky student and one lucky organization will win the fancy-schmancy Prusa i3 MK3, with the neato multi-extrusion upgrade. [Budiul] is a student, so he figured he would repair something with a 3D printer. Lucky for him, the pegboard in his workshop was completely terrible, or at least the pegboard hooks were. These hooks were made out of PVC, and after time, more and more hooks broke. The solution? Print his own, and make them stronger in the process.
[Budiul] started his fix by taking the remaining, unbroken hooks on his pegboard wall organizer and measuring the relevant dimensions. These were modeled in Creo 4.0, printed out, and tested to fit. After many errors and failed models, he finally got a 3D printable version of his plastic pegboard hooks.
Of course, replacing PVC pegboard hooks with ABS hooks really isn’t that great of a solution. To fix this problem of plastic pegboard hooks for good, he printed the hooks in halves, with a channel running down the middle. This channel was filled with some steel wire and acetone welded together. The result is a fantastically strong pegboard hook that will hold up to the rigors of holding up some tools.
While printing out pegboard hooks might not seem like the greatest use of time, there are a few things going for this hack. Firstly, these aren’t the pegboard hooks made out of steel rod we all know and love; this is some sort of weird proprietary system that uses plastic molded hooks. If they’re made out of plastic anyway, you might as well print them. Secondly, being able to print your own pegboard hooks is a severely underrated capability. If you’ve ever tried to organize a workbench, you’ll know that you’ll never be able to find the right hook for the right spot. There is, apparently, a mystical superposition of pegboard hooks somewhere in the universe.
This is a great hack, and a great entry for the Repairs You Can Print contest. You can check out a video of the hack below.
8 thoughts on “Repairs You Can Print: Fixing Pegboard Clips That Break Too Easily
      1. There’s at least one style of slatwall with steel lined T slots which can accept either the slatwall hooks or any standard pegboard hooks that only have the two prongs at the top.
    1. My Apology for the semantics gripe again. Especially in view of my own grammatical and spelling misfires. :d
      Yeah, but this language creep makes having a conversation reeeaally confusing or difficult at times.
      I’ve witnessed more than one argument (online & “real life”) that simply was a result of this misnomer-ization.
      Or when you are looking for something online and the naming/descriptor of said thing has been “contaminated” and thus you keep getting wrong/wasted search results….sigh.
      I get the “language is a living thing” concept, but in some situations, all we are doing is creating chaos, not improving our lives.
      This site has a pretty good sized audience. I just wish you good folks wouldn’t contribute to the chaos. :)
  1. So those many attempts made me think: are there devices that re-melt failed projects back into filament? Because that would be a good business, and a relatively simple device seeing it doesn’t need positioning.
    Or how about a 3D printer that just has a tray you dump PLA chucks in and it’ll use that as filament?
Leave a Reply to Mike SzczysCancel reply
