A Daylight-Readable Bar Graph Display In The 70s Wasn’t Cheap
The driver board with display attached; the row of lamps is visible on the right hand side.
LEDs weren’t always an easy solution to displays and indicators. The fine folks at [Industrial Alchemy] shared pictures of a device that shows what kind of effort and cost went into making a high brightness bar graph display in the 70s, back when LEDs were both expensive and not particularly bright. There are no strange materials or methods involved in making the display daylight-readable, but it’s a peek at how solving problems we take for granted today sometimes took a lot of expense and effort.
The display is a row of 28 small incandescent bulbs, mounted in a PCB and housed in a machined aluminum frame. Holes through which to view the bulbs are on both the top and front of the metal housing, which allows the unit to be mounted in different orientations. It was made as a swappable module, its 56 machined gold pins mate to sockets on the driver board. The driver board itself consists of 14 LM119 dual comparators, each of which controls two bulbs on the display.
An example of a Wamco minitron bar graph display. Each window contains an incandescent filament. [Source: industrialalchemy.org]
[Industrial Alchemy] believes that the display unit itself may have been a bit of a hack in its own way. Based on the pin spacing and dimensions of the driver board, they feel that it was probably designed to host a row of modular units known as the Wamco minitron bar graph display. An example is pictured here; they resembled DIP chips and could be stacked side-by-side to make a display of any length. Each window contained an incandescent filament in a reflective well, and each light could be individually controlled.
These minitron bar graph units could only be viewed from the top, and were apparently high in cost and low in availability. Getting around these limitations may have been worth creating this compatible unit despite the work involved.
Display technology has taken many different turns over the years, and you can see examples of many of them in one place in the Circus Clock, which tells the time with a different technology for each digit: a nixie, a numitron, a 7-segment thyratron tube, a VFD, an LED dot display, and a rear projection display.
4 thoughts on “A Daylight-Readable Bar Graph Display In The 70s Wasn’t Cheap
  1. Hmm, good to look back on early electronics, I saw something like this on a beta particle Cs137 scintillation counter circa 1978-9 rather coarse but gave a quick indication something was blocking the beam…
    These days with SMT leds, Charlieplexing, CPUs etc we can do all sorts of new and interesting display modules maybe also form factor compatible with older electronics offering wider diversity and few commercial opportunities too. Thanks for posting, nice to see, takes me back :-)
  2. I think everything’s good. How quickly did you forget the Nokia 3310 phones? Or Machintosh? :) Technology is now at hand. We have the freedom to do everything we want, every moment. You know best what can be done with Arduino, don’t you? Thanks
Leave a Reply to Arduino Forum Cancel reply
