Dim Hallway Gets Lighting Upgrade
There’s nothing worse than a lightswitch that’s nowhere near where it should be, leaving you fumbling around in the dark. [supersquirrel72] had just this problem, and decided to put an Arduino to work instead.
Rather than using the original mains lighting that was poorly positioned and not enough to light …read more
