Low-Tech Fix Saves Expensive, High-Tech TV From Junk Pile
Wiggling this connector caused the backlight to turn off and on.
[Tweepy]’s TV stopped working, and the experience is a brief reminder that if a modern appliance fails, it is worth taking a look inside because the failure might be …read more
