Liquid Lite Brite Robot
Liquid handling workstations are commonly used in drug development, and look like small CNC machines with droppers on the ends which can dispense liquid into any container in a grid array. They are also extraordinarily expensive, as is most specialty medical research equipment. This liquid handling workstation doesn’t create novel drugs, though, it creates art, and performs similar functions to its professional counterparts at a much lower cost in exchange for a lot of calibration and math.
The art is created by pumping a small amount of CMYK-colored liquids into a 24×16 grid, with each space in the grid able to hold a small amount of the colored liquid. The result looks similar to a Lite-Brite using liquids instead of small pieces of plastic. The creator [Zach Frew] created the robot essentially from scratch using an array of 3D printers, waterjets, and CNC machines. He was able to use less expensive parts, compared to medical-grade equipment, by using servo-controlled valves and peristaltic pumps, but makes up for their inaccuracies with some detailed math and calibration.
The results of the project are striking, especially when considering that a lot of hurdles needed to be cleared to get this kind of quality, including some physical limitations on the way that the liquids behave in the first place. It’s worth checking out not just for the art but for the amount of detail involved as well. And, for those still looking to scratch the 90s nostalgia itch, there are plenty of other projects using the Lite Brite as inspiration.
Thanks to [Thane Hunt] for the tip!
2 thoughts on “Liquid Lite Brite Robot
    1. Hmmm, do you know how inkjet printers work? In my opinion, an inkjet printer is not at all a good starting point for a project like this….it is missing a Z axis and the other axis requires moving the fluid cells back and forth, which, as the author mentioned, is not a good idea. If you are saying that an inkjet printer is great for printing colored dots on paper then I cannot disagree with you! ;)
Leave a Reply to thaneCancel reply
