2022 Hackaday Prize: Sensible Flow Helps You Keep Track of Your Water Usage
Safe, clean drinking water is a scarce resource that shouldn’t be wasted. But it’s not always easy to see how much you’re using when you turn on the tap: is … Continue reading 2022 Hackaday Prize: Sensible Flow Helps You Keep Track of Your Water Usage
