Massive Aluminum Snake Casting Becomes Water Cooling Loop For PC
Water cooling was once only the preserve of hardcore casemodders and overclockers. Today, it’s pretty routinely used in all sorts of performance PC builds. However, few are using large artistic castings as radiators like [Mac Pierce] is doing.
The casting itself was inspired on the concept of the ouroboros, the snake which eats its own tail if one remembers correctly. [Mac] built a wooden form to produce a loop approximately 30″ tall and 24″ wide, before carving it into the classic snake design. The mold was then used to produce a hefty sand cast part which weighed in at just over 30 pounds.
The next problem was to figure out how to create a sealed water channel in the casting to use it as a radiator. This was achieved by machining finned cooling channels into the surface of the snake itself. A polycarbonate face plate was then produced to bolt over this, creating a sealed system. [Mac] also had to work hard to find a supply of aluminum-compatible water cooling fittings to ensure he didn’t run into any issues with galvanic corrosion.
The final product worked, and looked great to boot, even if it took many disassembly cycles to fix all the leaks. The blood-red coolant was a nice touch that really complemented the silvery aluminum. CPU temperatures weren’t as good as with a purpose-built PC radiator, but maxed out at 51 C in a heavy load test—servicable for [Mac]’s uses. The final touch was to simply build the rest of the PC to live inside the ouroboros itself—and the results were stunning.
We’ve featured a few good watercooling builds over the years. If you’ve found your own unique way to keep your hardware cool and happy, don’t hesitate to notify the tipsline!
5 thoughts on “Massive Aluminum Snake Casting Becomes Water Cooling Loop For PC
    1. No nations that use napoleonic units practiced imperialism?
      FREEDOM!’s weight is typically measured in grains, but pound next best thing.
      The art seams rudimentary.
      For all the casting effort, I’d have spent anther week on carving first.
      Snake’s head looks like PacMan.
      Ask an artistic friend for help.
      You could design cooling fines into the casting by choosing a better positive material than wood.
      They purpose make both foam and casting plaster for such things.
      You could even cast in a water passage.
Leave a Reply to JamesCancel reply
