Our loyal reader [Everett] has hacked up a CVS single-use camcorder to use as a nightvision scope. This is his second prototype. The first one only had 4 cruddy IR LEDs from Radiohut and a front mounted battery pack. For the second one, he separated the batteries from the camera. He removed the IR filter from the CCD and added 8 higher quality IR LEDs. On the backside of the camera is the eyepiece from a Handycam. It keeps the the LCD screen from leaking light and has a lense to help the eye to focus on the screen. The LCD is to bright to use without adding a dimmer pot. The camera is mounted to a headlamp rig with the batteries on the backside of the head. It may not have the best image quality, but at $35 you can’t go wrong when it comes to nightvision fun.
