Metasploit Running On A WRT
metasploit
The folks from See-Security have gotten the Metasploit Framework running on a Linksys WRTSL54GS. They were inspired after seeing the Hacker Pimps pen-testing firmware, which we’ve covered before. The Metasploit Framework is used to develop and execute exploit code against target machines. The See-Security team ran into trouble getting Metasploit running due to RAM limitations. This particular model of router has a USB port so they were able to create swap space on a flash drive. The web interface worked as well once they set the bind address to the gateway IP. They’ve got all the steps you need to do this starting with OpenWRT.
[thanks muts and stillbourne]
Continue reading “Metasploit Running On A WRT”
