Alpha Radiation Visualizer
alpha visualizer
[Jared Bouck] certainly has a unique project on his hands this time. He started out wanting to build a somewhat complex system for visualizing Cherenkov radiation. With a little investigation he found some new ideas and decided to build a really compact apparatus. Cherenkov radiation is seen as a blue flash when a particle passes through a medium at a speed greater than the speed of light in the medium. Jared used a webcam CCD as the medium and a small piece of radioactive americium sourced from a smoke detector. The camera housing is sealed from any light leaks and is shielded to block EMI. Watching the camera output you can see flashes of white and blue streaks.  It’s a neat home built demo and I bet it could be used as a random number generator as well. In the real world, scientists use Cherenkov radiation detection to determine fission reaction intensity, measure radioactivity in spent fuel rods, and detect the origin of cosmic rays. Similar techniques are used in neutrino detectors like the massive IceCube project.
47 thoughts on “Alpha Radiation Visualizer
  1. wow dude, i didnt know that smoke detectors had nucler bombs in them, damn i shouldnt have eaten that smoke detector that day.
    really nice thou, i dont know what you use em for but hey, its a hack, who cares.
  2. wow #2’s post is so wrong I won’t even bother. a friend and i are working on a high altitude cosmic radiation experiment and seeing how a simple webcam can detect (at least) alpha particles is sweet — i’ll have to keep this hack in mind :)
  3. This is really very brilliant. Definitely the definition of a hack in my book.
    I am really interested in this as a RNG, I wonder what it would take to right some software to convert the random appearance of those white dots to data that could seed /dev/random?
  4. Wow, this it really cool. Is there any way to make actual measurements with this tool, or is it just to visualise it? doesn’t look very spectacular though if you don’t know what’s going on.
  5. This is a very cool hack, if for no other reason than it involves radioactive materials. The USB-card-turned-detector makes for a very clean package, and is dual purpose!!
    TJ: Can’t get much more random than the P3 and later CPUs. They use a thermal resistor as their “chaotic” source.
    Now if that isn’t quite enough go to Wal-Mart and pick up the cheapest digital camera you can find ($15 at my local store), place a piece of black electrical tape over the lens (or point it at something that is constantly changing… Like the trees in the front yard), connect it to your PC, and use the software infl00p mentions… Or other projects like: http://www.lavarnd.org/index.html (previously listed on hackaday)
    The cheaper the camera, the more “noise” they pick up on their image sensor. The el-cheapo cams at Wal-mart are about as low as they get.
    Practically anything could act as a “chaotic source”… A combination of temperature, barometric pressure, and humidty, untuned (or tuned) FM radio or TV, a microphone stuck to the inside of the PC case… Possibilities are endless.
  6. Ed3,
    “Cheaply made” cameras are technically no better or worse for the task than any other kind of camera, because their errors are typically either repeatable or cyclical. When you’re looking for ‘randomness’ or ‘entropy’, whether the image is in- or out-of-focus doesn’t change the outcome.
    It does, however, change the price, and for that reason alone you are better off using a cheap camera.
  7. #12 – Nardo…
    While I completely agree… its really not super important for this project as you never need to remove the shielding around the Americium. But, being cautious does not hurt :P
  8. A smashing hack! If you were to place a thin layer of zinc sulfide on the CCD you might make a more sensitive ‘scope. The ZnS will glow (release a photon) when an alpha particle strikes it.
  9. For a simple random number generator wouldn’t an AM radio tuned to an empty channel work just as well?
    Just take the audio and feed it into a sound card.
    I call it the cheap Tom Clancey random number generator.
  10. hi.. i did something similar to this a while back, in my case the aim was to build a cheap tubeless Geiger counter.
    It did work but the main problem was the chip’s light sensitivity, never did find a way to fix that properly.
    I had to replace the front of the sensor (used a cheap B&Q junk camera as it had a bare chip with no glass) with mica washer to get any decent sort of count though,painted with silver to get the required light blocking.
    hope this helps, btw email me for the “hard to get” parts if you know what i mean :)
  11. One idea for the random number genorator would be mplayer with the md5 video out device… Just a few changed pixels will totally throw off your md5 sums. Just a thought.
  12. I tried this same experiment with great success. Tore apart a GE webcam, carefully removed the glass from the CCD chip, and placed the americium sample in front of the CCD. I found I could perfectly place the americium sample inbetween the lens housing and CCD face then secure it by screwing in the lens. This cut out all external light and held the sample steady.
    Here is an animated GIF of my results. I also noticed the CCD was picking up dots as well as an intermittent energy bursts (gamma?). I read that CCDs can detect gamma rays and americium has some low energy gamma emmissions. It shows up on the upper area as a pulsating glow. I’ve seen a few times where the whole screen flashes as a possible gamma ray hit the CCD directly. The static red/green/blue smaller dots are my CCD chip having a nuclear meltdown. The CCD pixel capacitors are being slowly fried with every alpha particle detection.
    CCD alpha particle emission detection GIF:
    http://img153.imageshack.us/img153/2310/alphaccddetectionaa1.gif
  13. The Day the Earth Stood Still is a 2008 science fiction film, a remake of the 1951 film of the same name.
    Actually, after i’ve seen it, I was dissapointed. Perect cast, interest theme, but scenario doesn’t conform to modern world-view and lifestyle.
    Interest ot hear other opinions, do you like this movie?
  14. A top-secret news.
    Barack Obama and Osama bin Laden came to an agreement about the future of US. It’s the new page in US history. :(
    There is no America now at whole!!!!!!!!!!!! Only terrorists and money, it’s all Obama intrested in.
    Watch the video !!!. :(
    Watch quickly. The video will be deleted by hoster because of politics. !!!
  15. Please give me a prompt about a virtual numbers company with the bigest country coverage and cheap call forward to mobile phone which gives 800 number? I need to get numbers in the Argentina, Hungary, Georgia, Israel, Kazakhstan, Korea, Netherlands, Poland, Philippines, Chile, Japan.
  16. Хотите насладиться самым классным сексом по телефону? Здесь вы найдёте высокий уровень обслуживания и самые нежные голоса, которые реализуют ваши самые дерзкие и страстные сексуальные фантазии. Всё то, что вы мечтали сделать в жизни найдёт своё воплощение. Вы сможете сами выбрать себе партнёра по вкусу и насладиться сексом без границ и запретов. Забудьте об обычных сервисах секса по телефону. Здесь вам окажут только самые лучшие услуги, которые по-настоящему распалят вашу фантазию и доставят непревзойдённое удовольствие! Занимайтесь сексом по телефону только с лучшими партнёрами и реализуйте ваши самые сокровенные сексуальные желания с нами!
  17. Attention to all players, and those people who cannot without MMORPG.
    The new game portal PROMMORPG, soon opens new game servers:
    1. Rising Force Online (RF Online);
    2. LineAge II;
    3. Perfect World;
    4. World of Warcraft;
    All games are absolutely free, no playing players from administration.
    The newest games and the advanced equipment for them.
    Fast communication channels and reliable data centres.
    All can be found it on a game portal http://www.prommorpg.com
  18. This week, millions of people watched Obama’s inauguration on the Internet through one of the many sites that offered a live feed. CNN’s broadcast was without doubt one of the most used viewed streams, with a peak of more than a million simultaneous viewers and also one that was using P2P technology. More…
  19. Продаются земельные участки от собственника
    20-26 соток, от 36.000 руб за сотку
    Назначение – под дачное строительство
    90 км от МКАД, Серпуховский район (Симферопольское ш.), р.Нара
    Заказать показ участка можно по телефону (495) 967-5678
  20. Продаются земельные участки от собственника
    20-25 соток, от 100.000 руб за сотку
    Назначение – ИЖС, без подряда
    70 км от МКАД, Чеховский район (Симферопольское ш.), р.Лопасня
  21. Говорил мне отец что покрышки нужно выбирать грамотно и осторожно, я сначала не верил как ��сегда, но вот посудите сами:
    Колеса для бескамерных шин, должны обладать высокой герметичностью сварного шва (колеса с диском), а также иметь на посадочных полках обода специальные кольцевые выступы тороидальной формы (“хампы”), предотвращающие самопроизвольное соскальзывание бортов шины (разбортигровку) в случае критических ситуаций во время движения.
    Неплохо? То-то же!
Leave a Reply to yourporn com liteCancel reply
