Tiny FM transmitter bugs rooms
Lucid Science delves into spy-tech once again with this tiny FM transmitter. Their post demonstrates a bit larger version than seen above, using a 9-volt battery and protoboard sized to match which makes for easier soldering. The design uses a microphone, two transistors, enameled wire for the coil, as well as various resistors, capacitors, and a potentiometer. What you end up with is an amazingly clear audio signal that can be picked up with a normal FM radio.
This would make a great project to do with the kids. You can talk about circuit design, practice soldering, and when finished they’ve got an almost miraculous toy to play with. Just be careful what you say around the house, the room might be bugged!
Comments
  1. Richardf says:
    I find and crush at least three or four of these every day when I get home from work. These bugs keep crawling behind my picture frames and into the smoke alarm. Think I should call an exterminator?
  2. RadBrad says:
    Thanks once again for linking to one of my projects. The goal here is to show a step by step build process of the basic transmitter to the electronics beginner. The transmitter does work well, but it does have limitations.
    Cheers,
    RadBrad
  3. Chajtek says:
    I was soldering similar circuit 15 years ago.
    This is realy nice circuit. Only issue is that it changes freq when battery power is dropping.
    It will be interesting to do the same with smd components, smaller microphone and may be quartz. I bet it can be size of microphone you have used.
    This could be nice contest to build fm transmitter from smd elements found on 3.5′ floppy drive.
  4. biozz says:
    @Richardf
    dont worry … transmitting devices occur naturally and if you can change the batteries on them every 9 weeks it would be a big help :3
    feel free to read your personal information aloud and use the NATO phonetic alphabet :3
    you can hide these things anywhere! … but FM might not be the best band to use seeing that most people have a receiver for it XD
  5. M4CGYV3R says:
    I used to make all manner of these things when I was a kid and put them all over my house. My parents hated it but it totally got me into circuitry and electronics.
  6. ehrichweiss says:
    Chajtek: Assuming it wouldn’t take up tooo much room on the board, you could always use a joule thief type circuit to keep the voltage semi-stable until the very end of the battery’s life.
  7. strider_mt2k says:
    Reminds me of the ones Radio Shack used to sell, only this one is probably a bit better, you know…because of the love.
    The Shmack ones I used to bump up the power a little and put larger batteries on ‘em and simply drop em in the grass in front of my house at night.
    One on either side of my property, you guessed it, each tuned a bit apart on the band and tuned in on separate radios spaced apart in my room for a decently realistic stereo image of cars and pedestrians passing by.
    Good times!
  8. Davo1111 says:
    strider_mt2k – thats actually quite cool
  9. Tom says:
    Frequency also changes a lot depending on the amount of capacitive load at the antenna. Or where the device is placed. Not stable at all.
  10. RadBrad says:
    Greets Stider.. It has been a while! Do you still have your cool ROV up and running?
  11. bilbao bob says:
    smd versions of this are pretty simple, but it’s easier to go up in frequency with SMT parts. In general the L and C components are larger at FM frequencies. These are (were) fun, but it’s even more fun to use them as beacons to be located with directional antennas. Just replace the microphone with an oscillator of any kind and put it in your car. You can track it with a small radio.
  12. John Smith says:
    The transmitter doesn’t have to be that stable because of FM’s capture effect. It can drift quite a bit before it causes problems. I’d guess it could drift a few 100khz either way with no problems.
  13. caff says:
    There was a really wonderful series of books I read as a teenager, the best of which was called “14 FM Bugs to Build” by Colin Mitchell.
    Anyone interested in small fm transmitters / bugs should have a look at it.
    http://www.talkingelectronics.com/shop/products/14-FM-Bugs-to-Build.html
    My favourite was the 9v battery top voyager (with the first smd I ever soldered):
    http://talkingelectronics.com/projects/Voyager/Voyager-P1.html
    And the Amoeba because it fit so perfectly in a tic tac box with it’s 2 AAA batteries.
    http://www.talkingelectronics.com/shop/products/Amoeba.html
  14. i like it! looks cool :-)
  15. strider_mt2k says:
    @RadBrad : Hey long time no see! -great hearing from you!
    Yeah “Probe II SG” is in a closet in “mothballs”.
    I need to bring it out and look into modernizing it!
    Hope you and yours are well! :D
  16. ejonesss says:
    now the site is down
    thanks hackaday.
  17. Binky says:
  18. xorpunk says:
    I’d at least use some modulation obfuscation..also there are designs that filter the same or better with less filter components..
  19. cgmark says:
    I would like to see more people using just the basic components to build stuff. Everyone has jumped on the ‘you need a chip’ to do things that they forget how much can be done with just transistors, resistors, capacitors. Here is a page that has a free ebook download with 200 transistor circuits and some of them are transmitters.
    http://www.talkingelectronics.com/te_interactive_index.html
  20. qwerty says:
    I made a lot of stuff like this many years ago, but it’s the first time I see someone laying components on the schematic as in the second picture at http://www.lucidscience.com/pro-basic%20spy%20transmitter-5.aspx
    I absolutely love this way of letting newbies familiarize with parts. Bravo!
    The frequency drift can be reduced a lot by putting the RF circuit behind a screen, using an additional RF buffer stage, regulating the power supply and compensating for temperature by choosing the right parts. But that would make the circuit much bigger and harder to build by a newbie.
    About 20 years ago I managed to build a FM transmitter using a CB xtal on the main oscillator then tuning the RF amp to the 4th harmonic (27MHz*4=108MHz). You can’t get more than a few KHz of deviation when modulating a xtal on the fundamental freq, but its 4th harmonic had enough juice to be heard loud and clear from a commercial FM receiver. Definitely not HiFi though it was more than enough for bugging.
  21. xorpunk says:
    Back in my day you either built it with wood, or you built it with stone!
    .o(sorry had to do it xD)
    People who were doing this stuff x years ago are a dime a dozen..no offense. Its not even intermediate HAM level.
  22. fartface says:
    @biozz FM is a transmission mode not a “frequency.
    I can transmit FM that most people cant receive.
    Sounds like an RF and Radio refresher is needed here.
  23. bilbao bob says:
    ah, the joys of growing old.
    I really like to see people doing this stuff and documenting it. I ended up with a pretty state of the art lab, but I started by burning myself with a soldering iron like everyone else.
    I remember running into old guys with silent machine shops in their garages and wondering why the hell they wouldn’t be making stuff with it – they knew how to do anything. CNC gear, full on machining centers, wood working tools and near production level chemistry labs. All gathering dust, and generally with an airplane around somewhere.
    And now my stuff sits around and gathers dust and loses calibration. A few years ago, I gave a kid a 5 digit meter and a 100 mhz scope because he showed me a little data logger cobbled up from a breadboard using a pic chip. He was 14.
    But I could see he ahd the fire.
    My imagination ALWAYS outstripped my skill level, but I guess that’s the way it should be; As soon as I had working neon blinkers I wanted to build a computer; After building a couple of computers I wanted to work on AI; after I could do SMT I wanted to ship masks to be fabbed; and so on through a whole range of technologies. It’s a great life for a hacker, even if my brain could use a couple of defrag passes and a bit of cleanup.
    But even putting serial numbers on white blood cells doesn’t come close to beating the experience of connecting all those parts up based on faith that the schematic meant something, and then hearing my own transmitter on the radio.
  24. J.D. says:
    Great…the only problem is in the USA even possessing the above device will get you 5 to 10 in the big house! You may want to check out 18 USC 2512 before you build the above.
  25. chris says:
    love the old school phone
  26. golddigger says:
    Slightly off topic, but does anyone know where I can find a class I laser range finder? I should add not the hand held size, I need a small setup. Thanks!
  27. Chaemelion says:
    Well it works beautifully! Made myself one last night. Couldn’t find a single .22 uF cap in all the boxes of broken electronics I have, so I had to solder 2 #104 caps together. Awesome little device.
  28. Chajtek says:
    J.D. hopefully not all readers on this forum are from US. Do you have blue-tooth headsets in US? It looks like they are against this regulation.
    There should be big distinction between doing thinks for fun with short range. In Europe as long as you are not making troubles it is OK. When you will start making them someone will knock your doors.
  29. zeropointmodule says:
    in the uk they are totally illegal under the WTA 2006.
    i built a few of these many years ago, and they were never particularly stable leading to many problems.
  30. bilbao bob says:
    @JD
    This secret microphone crap is basically kid stuff. Anyone trying to use this stuff for real is messed up; You know, unless it’s the government doing it.
    Wiretap laws are like sodomy laws – people that are gonna do it are gonna keep on doing it, and once in a while there will be an example made, but otherwise we’ve all long since forgotten what privacy was there for in the first place.
    But in the meantime, the 350 people on the planet with soldering irons who want to play with this stuff are unlikely to use it for more than a day or two. One or two guys or girls will be nuts enough to use it for stalking or spying on auditors, and they’ll get smacked for it.
    But as the Stazi learned, most people are really, really boring. Even dissidents. Building a transmitter is fun, but apart from lonely old guys with scanners, we don’t generally care about other people – half the time, I can’t be bothered to listen to people when they’re standing next to me, let alone want to listen to them when they’re away.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,041 other followers
