A ham radio receiver, Manhattan Style
manhattan_style_circuits_the_red_not_the_white
If you’ve never heard of “Manhattan Style” circuit construction, you’re not alone. Popular in ham radio circles, the process looks nicer than straight dead bug style circuit building, but not as involved as etching your own PCB – consider it a nice middle of the road solution.
This type of construction is often used to build circuits inside enclosures that are made of copper clad, which is a somewhat common practice among ham radio operators. Manhattan Style circuits are built using glued-on metal pads to which components are mounted. One might think that the large pads you see in the image above would limit you to through-hole components, but that’s definitely not the case. A wide array of SMD pads are available in common pin configurations as well, allowing you to use pretty much any type of component you prefer.
While it might not be appropriate for every project you work on, Manhattan Style circuits and copper clad boxes definitely add a nice touch to certain items, like the Wheatstone Bridge Regenerative Receiver you see above.
[via Make]
Comments
  1. teeh says:
    A prime design and stand up circuit.
  2. Sherise Christinsen says:
    For iPhone, iPod touch, and iPad you can also get serial number from iTunes or on the device by clicking Settings > General > About Just scroll down and you’ll see Serial and other data.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
