Tornado lamp made with lasers
[Styropyro] did a great job of taking common parts and making an interesting item. He calls this his Tornado lamp, and it’s made with stuff you probably have around the house — well you might have to substitute more common glassware for that Erlenmeyer flask.
The bulk of the hack is in the base. You’ll find a laser diode pointed at a small scrap of mirror. That mirror is mounted on the center of a small case fan, giving the tornadic effect when spinning. To make everything fit just right, the laser is pointed horizontally, with the fan/mirror at a 45 degree angle. The beam points up through a hole in the project box and illuminates the liquid in the flask. That liquid is water doped with a substance that fluoresces. In this shot it’s some fluorescein, but we did mention you can do this with stuff from around the house. [Styropyro] demonstrates the use of liqud from some highlighting markers as a substitute.
If you’re decoration a mad scientist’s lab this is a perfect companion for a Jacob’s ladder.
Comments
  1. Keith says:
    That’s got real potential. Turn it in to a magnetic stirring device as well for a real vortex and the laser should just add to it.
  2. Ken Quast says:
    Nice hack with common items. FYI, I have a post on my site that has the same dye extracted from a highlighter as you mentioned. Post shows extraction method and a link to the MSDS and a faux neon “light” just for fun.
    http://www.observationsblog.com/3/category/neon/1.html
  3. Johnny O. Farnen says:
    Why waste all that time gutting markers or dropping cash on flourescien when some extremely cheap tonic water will give you that exciting Nuka-Cola glow?
  4. conundrum says:
    Tonic water isn’t as bright, IMHO.
  5. matseng says:
    Do you get those nice swirling/flickering effects in real life as well or is that just an artifact from the cameras framerate vs the speed of the mirror?
  6. ino says:
    It’s nice.
    He can also narrow the vortex and add a second mirror on the top of the flask for some more effects.
    @matseng
    I would say artifact.
  7. Phlogiston says:
    I suspect the cool swirling effect is an artifact of the frame rate of the camera and the rotating beam.
    Then, however, a simple (and quiet) lens that spreads the beam will produce nearly the same effect as the spinning mirror.
  8. Hirudinea says:
    Everythings better with lasers!
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
