In the last few months, software defined radio has seen an explosion in popularity thanks to a small USB TV tuner dongle able to receive anything broadcast between 64 and 1700 MHz. It’s a very neat project that opens the door to a whole bunch of radio experimentations, but getting started in the SDR world can be a bit daunting. To help everyone out, [MS3FGX] is writing a getting started guide so everyone can get into the world of software defined radio.
After getting one of the TV tuners supported by the RTL-SDR project (by far the most commonly used is this one from Dealextreme), the next thing you’ll need is a decent antenna. [MS3FGX] has had some success with this Radio Shack antenna, but it’s very easy to make your own.
The most popular software package to use with the RTL TV dongle is GNU Radio, and [MS3FGX] goes over the ins and outs of setting this up along with a brief aside for the Gqrx receiver.
After your hardware and software is set up, the only thing left to do is tuning into a few of your favorite stations. The range of frequencies the RTL covers includes AM and FM radio, along with GSM and GPS signals. Of course there’s a whole lot more you can do with this project like listening in on your car’s keyless entry fob, pagers, and wireless weather stations.
Subscribe for weekly videos
Has anybody grabbed weather satellite images with one of these? They appear to properly support fm-wide well enough – of course a better antenna would be golden.
Do you mean the APT stuff around 137MHz, or the LRPT at 1691MHz? APT should be easy enough, although I already have a setup made out of an old scanner dedicated to this.
APT, yes. I don’t expect much luck as far as LRPT goes.
Yes, I have heard of a few people receiving APT from NOAA satellites using RTL devices.
The main thing is that you need a good antenna and precise timing, as you need to get the strongest signal possible.
Also, RTL records in 8 bits, and most of the APT decoding software wants 16 bit, so you need to record the audio from Gqrx (or whatever you are using), then resample the audio at 11.025 kHz. You should then be able to feed it into APTDEC (http://atpdec.sourceforge.net/) and get decent results.
Getting NOAA sat images is one of my long term goals as I get more involved with SDR. At this point, I’ve been able to detect signals from some passing satellites with even the rabbit ears, but anything better than that will require a real antenna setup.
I get decent (not perfect) APT pictures from a Uniden Bearcat portable scanner and a J-Pole (don’t laugh — it works).
With the RLT-SDR and J-Pole, I can pick up NOAA Weather Radio voice signals on 4 of the 7 allocated frequencies with a bit of static — not quite as good as the Bearcat. Therefore, I wonder with the RTL-SDR if I would have to go an aimed yagi to pick up APT…
^I was wondering about the input sensitivity of these compared to “real” equipment, also. In my experience, TV tuner adapters don’t have as good of sensitivity compared to most digital TVs, so I wonder how they would compare to the frontend of a true scanner or radio. I wonder if an low-noise amplifier would help this, also…
I’ve been following these guides for a couple of weeks now including this most recent getting started guide. I’m not a Ham or even very experienced but there are a ton of extra resources on the RTL-SDR subreddit (http://www.reddit.com/r/rtlsdr)
HACKADAY
you have been mentioning SDR at least 3-4 times a week
you are giving all the wrong people credits
i hope you are doing this on accident
first of all lets get this straight
it is not balint
to my understanding he stole the real peoples work
goto ##RTLSDR on Freenode and talk to Patchvonbraum or Steve|m or m5sdos or something like that
they will tell you the hole (REAL) story
please someone get the hackaday guy to do this.
im so tired of the guys who developed this not getting ANY credit at all
Agreed,
The real people working on this are Steve|m, m5dos(dos_fan]), prog, and a few others in ##rtlsdr on irc.freenode.net.
Basically what I’ve seen is balint and other people stealing code for their own personal gain in HDSDR and the extio. *Please give the others credit* and also realize that HDSDR is absolute garbage closed software. The devs even deny certain SDR transceivers to get TX support from HDSDR.
I think TV tuner adapters is not best option for real picture from my view Digital TV is best for broadcast.
Well, starting at 64 MHz, the RTL dongle will not receive AM broadcast stations, but rather transmissions in Amplitude Modulation. VHF analog AM transmissions left are in the airband(s) or some public services in some areas of the world.
Then, instead of listening to the bunch of data sent by RF remote controllers, a more clever way would be to try decoding it so that you can interface your weather station remote sensor and so on.
Last but not least, if Coldplay are going to play somewhere near you, you could use RTLSDR to tune into their xyloband control frequency, take a few recordings and then share how to switch them on again… ;-)
I am curious… why do these RTL USB devices using the RTL2832U/E4000 chipset have a gap in their receiving frequencies from ~1100-1250MHz?
http://www.jneuhaus.com/fccindex/960_mhz.html
Probably because it’s used for:
* Joint Tactical Information Distribution Systems (JTIDS) – Military and Government system utilizing spread spectrum techniques for terrestrial communication, navigation and identification
The other systems I’m able to verify do not lie within the blocked ban. It could also be totally unrelated, just a coincidence.
Interestingly enough, while I’ve been playing around with this I’ve found standard analog FM radio from much lower frequencies apparently being rebroadcast in the ranges of 840-855mhz. Anyone else able to confirm this behaviour?
Unfortunately I don’t have any other gear that can read these frequencies directly, so I’m not sure if the dongle is messing up, or whether something is genuinely being broadcast at that frequency.
Perhaps these are feeds for community repeaters?
I’ve seen something similar myself. I forget which frequencies they were on, but I was definitely getting faint rebroadcasts of FM stations well outside the FM range.
Recently I’ve been looking into getting a cheap “real” radio that has at least some of the range of the RTL devices so I can verify a few of the things I’ve been finding.
Like you, I can’t be sure if some of the odd signals I am picking up are real or due to glitches/limitations of the RTL setup.
You may be find the second harmonic of the original signals Google second harmonic
I found this also and a list of freq and the seconds
these are studio to transmitter fixed links, probably a yagi antenna so not super directional – you just happen to be enough in the pathway to receive it.
If you are hearing FM broadcast band signals around 932-940MHz you may be hearing the STL. Studio-Transmitter Link. Most radio stations don’t have their transmitters onsite. Rather, they have STLs to link the station. Though many are moving away from this method over to T-1s or, gaps, the public Internet, to ship the signal. Other places are around 150MHz & 450MHz for talk-back/in ear monitors for broadcast remotes. Enjoy listening.
air traffic control radar signals are in the 1100-1250MHz range. I was thinking that it would be fun to pick up the transponder signals with this thing but I guess i’ll have to keep looking…
if you mean ads-b people are doing that with gr-air-modes
Well lets see – got my EZTV645 stick + SDR#/Sharp
and Lenovo notebook to for a portable Sdr rig and it was pretty cool..
the EZTV645 v1.0 uses the fitipower fc0013 and was able to tun the entire range from 45mhz – 1000 Mhz
in my area the RF signal pickens were soo piss poor, after connecting to a 10ft home brew Conical antenna for 10 – 1500 mhz didnt increase what i could get, it just improved the signal level of what i was able to recive.
Playing with this sdr did have one benefit it saved me from spending 3500$ on a AOR 5000D wide band communcations reciver, to find out there nothing to much to hear.
thanks hacka a day !!!!
Oh by the way THE SDR was a very interesting experience despite the lack
Since I purchased 2 of these 645 units I will proabbly attempt buiilding a RF down converter to extend the upper end to 2Ghz band,
A broadband spiral approximately 24 inches wide should have acceptable enough performance at 137 MHz to receive the NOAA satellite broadcasts.
Generally, if you want to lower the lower frequency limit of a spiral, a shorted ring around the outside at the same distance as the outer rim is from the next in arm will allow you to reduce its size by around 30% That should work with both archimedean and log/equiangular spirals. You’ll also need a balun to feed it but a cheap 4:1 TV balun made for matching a 300 ohm antenna to 75 ohm coax should work (assuming 50 ohm coax) at 137 MHz because the feedpoint impedence of most spiral designs averages in the 150-200 ohm range
