After [Ch00f] got his hands on an 8×8 LED display, he didn’t make a 64-pixel video game or VU meter. He made a laser doodler, allowing him to draw on this display with only a laser pointer.
Using LEDs as light sensors is nothing new; [Forrest Mims III] discovered that LEDs can also detect light way back in the late 60s. [Ch00f] played around with this concept before creating a circuit that uses an LED as both a light emitter and sensor that reacts to the ambient brightness.
[Ch00f]‘s laser doodler takes this phenomena and applies it to an Adafruit bicolor LED matrix. When a light shines on an individual pixel in the display, the ATMega48 senses the current and turns that pixel on. Since this these pixels have two colors, [Ch00f] used a latch circuit and a button to cycle between what color the ‘Mega writes to the display.
In the video after the break, [Ch00f] shows off his display by having the LEDs light up in response to a laser pointer. It may be a bit small, but we can see a lot of potential for something like this as a gigantic art installation.
Subscribe for weekly videos
Very cool. And I think this hack can be used to even impress some chicks! Kudos dude.
Why not use different color laser to paint different color pixels ? I think there should be some sensitivity difference between different colored lights
I actually tried doing this with a red laser. The problem is that green LEDs will pick up very little from a red laser, and I can’t use the red LEDs as sensors without another 8 I/O ports on the microcontroller.
You are an impostor! There can only be one Robot.
(Nice work Ch00f, I would love to see an entire wall of these.)
- Robot
You could add seperate Leds for each colour, so you could point on the leds to switch the colour insted of pressing buttons…
There can be many many robots, and they must have unique names in order to be directly addressed.
So when will all LED screens become touch screen, by sensing no light where the finger is? … opps led screens only use LED for back light.
Love the creeper at the end.
You know, I actually have a use for this project! Might play around with this.
Make sure to send me whatever you come up with!
Rather than a button to select color, could you use a pulse modulated signal that the LED picks up to select the color?
I think this will be quite hard to do because LED’s are already dynamically driven. So decoding any modulation will be tricky.
isn’t this a repost? the only addition being a button you hold down that changes color?
http://cs.nyu.edu/~jhan/ledtouch/index.html
https://sites.google.com/site/studioelectricsheep/pj/2dphotodiodearrayusing8x8dotledmatrix
Does anyone else see the optical illusion? Where the dots appear in the black space on the grid? Stare at it for a while.
