Turning a Kindle into a weather display
Since the first time [Matt] saw an e-paper display, the idea of using it as a regularly updated, non real-time display consumed him. It really is the perfect platform for very readable calendars, agendas or, as [Matt] found out, a weather display.
[Matt]’s build uses a server to fetch and parse weather data and forecasts from NOAA. This data is then inserted into an SVG file, rendered, converted into a PNG, and finally converted into a grayscale, no transparency image required by the Kindle.
After the image is crafted by [Matt]’s server, a small script running on the Kindle fetches the image, clears the screen, and displays the image. This entire process happens twice a day, often enough for [Matt] to get a good idea of the weather outside without having to look out a window.
The really striking feature of [Matt]’s build is how good his weather display looks. The wonderful iconography of this weather display comes partly from graphics found on The Noun Project, with a few weather conditions drawn by [Matt] himself. It looks great, and is an awesome example of an excellent use of e-paper.
27 thoughts on “Turning a Kindle into a weather display
    1. At least there’s just so much of this stuff out there now that you can pick up used ones for a good price. Maybe not as cheap as the E-Ink display by itself, but if you get the whole package you have the option of using the wireless radios and system-on-a-chip to make your project more self-contained or portable.
    1. Someone could do this really easily with the browser and with javascript to load new pictures based on a timer, but it wouldn’t be as pretty as jailbreaking it because you could not hide the browser. You’d still see the navigation bar, the buttons, the title, etc.
  1. Looks pretty clean. I wonder how much work it’d take to make a simple e-paper display for this instead of using a Kindle? Would also be nice for watching system stats, similar to conky.
    [Matt]‘s build uses a server to fetch and parse weather data and forecasts from NOAA. This data is then inserted into an SGV file, rendered, converted into a PNG, and finally converted into a grayscale, no transparency image required by the Kindle.
    You mean svg (Scalable Vector Graphic)?
  2. I have a half working PRS505 here which as a broken lower half of the screen.
    Its a controller chip fault however the upper half still works.
    Wonder if this is feasible to turn into a ghetto fridge magnet weather / shopping display?
    I’ve re-waterproofed the display with Superglue and it seems stable, a couple of minor fine lines but not too bad.
  3. This is beautiful! I really wish there were e ink screens for sale that we could mess around with instead of having to use e-readers.
    I would certainly love an e-ink screen that would display the temperatures and humidity of my reptile cages. (Actually, that sounds like a good project to work on.)
  4. depending on your definition, i think this is real-time..
    for instance, in computing the definition is of real-time is: the update interval is fixed, and the computing must be finished before the next update.
    so this qualifies, because his display cycle is started 5 minutes after his retrieve/compute cycle. there is no check if the computation has finished, it is expected to finish in real-time.
    (this update happens only twice a day though.)
    see:
    http://en.wikipedia.org/wiki/Real-time_computing
  5. Cheapest one I’ve found is the Kobo
    which is about £39 over here.
    Shame the cheap one doesen’t have
    wireless, and no way to add it.
    So direct driving of the screen it
    is, or possibly use an MMC with an
    analogue switch IC to use a PIC to
    write/read data to it.
  6. there is a kindle weather app, but I don’t know if it has the across-the-room readability of this setup. and it probably can’t prevent the screensaver from activating. This as a screensaver would be nice, though.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
